parts nla
General queries KR Bikes
kwackman12
Post by kwackman12 » Mon Aug 11, 2008 6:30 pm
If anyone has a knackered crank complete with bearings that they could send me, I could get a local Garage to press it apart & see if I can get some numbers off it, I know they have a press as they rebuild Steam rollers / traction engines!! "HEAVY ENGINEERING" 8-[
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
Post by JanBros » Mon Aug 11, 2008 10:31 pm
2 pics I have on my PC :
red text = all bearings have a pin : diameter 3mm, center at 3mm off the edge
* first text : see above
* 2nd text bearring 2 : groove 2mm wide, diameter 59mm, 3mm off the edge
* 3th are bearrings andd seals once posted on the old forum
kwackman12
Post by kwackman12 » Tue Aug 12, 2008 8:18 pm
Thanks for that Jan, will print it off & try the shop tommorow
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
kwackman12
Post by kwackman12 » Wed Aug 13, 2008 11:50 am
Spoke to the shop today bearings are no problem but unable to supply them with the locating pins, they can get them fitted, but would have to be done by a "spark eroder" obviously the more we get done the cheaper the cost, but to do one it would cost approx £35.00!! :cry:
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
Post by JanBros » Thu Aug 14, 2008 12:11 am
kwackman12 wrote:Spoke to the shop today bearings are no problem but unable to supply them with the locating pins, they can get them fitted, but would have to be done by a "spark eroder" obviously the more we get done the cheaper the cost, but to do one it would cost approx £35.00!! :cry:
jep, I found the bearrings also in Belgium without the pins, and putting the pins in would cost about the same as the bearring itself :evil:
Why don't you just buy bearrings at BDK like I did ?
kwackman12
Post by kwackman12 » Thu Aug 14, 2008 10:50 am
Just looking at other options Jan, thought they were getting hard to source? might give BDK a ring to check on availabilty.
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
Post by Charles » Thu Aug 14, 2008 7:10 pm
kwackman12 wrote:, thought they were getting hard to source?
PJ got them as well:
http://www.pjme.co.uk/acatalog/KR1S.html
(see bottom of page)
cheers,
alanw
Post by alanw » Thu Aug 14, 2008 7:37 pm
Thorough As ever Jan :!: Alan.
fevsisere
Post by fevsisere » Sat Aug 16, 2008 9:58 am
Water pump gasket N.L.A
KR1S
350 powervalve
frog32
Post by frog32 » Sat Aug 16, 2008 7:50 pm
ok so here the list so far then
thanks for all the replys so far (ill update it as and when)
kr-1s lower exhaust mounting bracket
clutch thrust washer and pick up coil nla
Forks top adjusters
kips arms,wheels n valves....main bearings
rubber guide on the swinging arm
kr1/s std inlet/reeds rubbers
clutch cable
2 strokes our way of life :-)
Post by JanBros » Sat Aug 16, 2008 8:05 pm
wouldn't it be better if you keep the updateted list in your first post :?:
people will find it immediatly, and won't come up with the same things over and over :wink:
frog32
Post by frog32 » Sat Aug 16, 2008 9:29 pm
point taken jan amended :P
frog32
Post by frog32 » Mon Jan 26, 2009 1:01 pm
just called cradley kawasaki
and the idle screw for the right hand carb is nla :cry: aswell
part number 160211130
doom and gloom :-({|=
sorry cant ammend at the top of the tread
any chance of making this a sticky :?: ali
Post by tescr500 » Mon Mar 21, 2011 2:48 pm
i picked a pair of these recently Image
Post by Bertie_Mollie » Wed Sep 28, 2011 9:00 am
KR1 Rectangular washer plate for the swing arm protector NLA :(
KR1 Swing arm protector also NLA.
KR1 Bar ends NLA
KR1 / S Chrome front tank bolt and washer NLA.
KR1 Chain adjusters
Throttle Cable :shock:
Choke cable :shock:
GWB KR1s C2 - Now gone :-(
GWB KR1 - YES IT'S DONE!
AND NO S****Y H****A'S
Usque Ad Mortem Bibendum
Users browsing this forum: No registered users and 11 guests
