Question re 3XV TZR250.
General queries KR Bikes
Gerrit
Post by Gerrit » Tue Aug 28, 2018 4:50 pm
Does any of you who owns a 3XV TZR250 (or later 4DP, 4TW or 5KE TZ250) have a swingarm bearing sleeve, part No. 3XV-22184-00 lying around which can be measured? I need the following dimensions:
Overall length
Inner diameter (= OD of swingarm pivot shaft)
Outer diameter (= ID of needle bearings)
Length of bearing surfaces for needle bearings
Outer diameter of waisted section.
dmac
Re: Question re 3XV TZR250.
Post by dmac » Wed Aug 29, 2018 1:10 pm
HI Gerrit,
I can't help you on the dimensions, but if you have no luck here
http://pure2strokespirit.net/
TZR forum - as with here, there are some very helpful people - some are the same people as here :P
Gerrit
Post by Gerrit » Fri Aug 31, 2018 11:38 am
Thanks for the tip, dmac. I'll certainly check out that site!
Gerrit
Post by Gerrit » Fri Sep 07, 2018 5:09 pm
Thanks to a friendly member of the TZR board I have the required dimensions, but unfortunately my idea of using the TZR sleeve as a lightweight replacement for the KR-1S part is not on. Target weight for my KR project is the dry weight of the last TZ250s, 102-104 kg and to get anywhere near that will require every single part to be examined for possible weight reduction. The KR sleeve weighs a ton (502 g according to my digital kitchen scales) and is a prime candidate for slashing its weight. As it's nitrided this means grinding which is time-consuming and pricey, but unfortunately there's no alternative.
Post by JanBros » Fri Sep 07, 2018 5:38 pm
have one turned in aluminium
Gerrit
Post by Gerrit » Fri Sep 07, 2018 6:21 pm
Won't work, Jan- the swingarm needle bearings run directly on the nitrided sleeve and aluminium is simply unsuitable as an inner race.
Post by JanBros » Sat Sep 08, 2018 8:35 am
have one turned in alu with pressed on sleeves for, the bearrings.
or use different bearrings and an aluminium spacer between them, just like in wheels.
Users browsing this forum: No registered users and 7 guests
