Fork caps
smoovly
Fork caps
Post by smoovly » Tue May 05, 2015 10:30 am
Me again! :P
I am struggling to remove the fork caps from my S forks, they are so tight that the ring spanner has just rounded the nut off. Am I missing a trick or are they just seized?
I have seen some KR1 ones on eBay, are they the same as the S ones?
Many thanks
Jon
Re: Fork caps
Post by SP_BOTT » Tue May 05, 2015 10:50 am
I try and use a 6 sided socket on fork caps if possible, also try and crack the seal while they are still in the yokes, as this helps before removing the individual legs.
Fork legs differ as the caliper mounts are different for both models, believe the tops are the same tough.
smoovly
Re: Fork caps
Post by smoovly » Tue May 05, 2015 1:51 pm
Thanks, I will give that a go.
Professor
Re: Fork caps
Post by Professor » Wed May 13, 2015 11:11 pm
Make sure the top yoke clamp is loose when you try to loosen the cap as it can pinch the thread tight.
Hardcore you know the score
