Swingarm to sprocket Dim
Wheels, shocks, forks, frame
Post by scooble »
could someone please post the distance between the inside of the swingarm to the outside face of the (rear)sprocket so that I can check my chain/sprocket allignment (for a KR1, not sure if KR1S is different)
buzinc
Post by buzinc »
You mean here?
Pic of wheel with no chain adjustment, ie pushed forward.
Distance from sprocket to swingarm about 15.5mm. This is the bottom 'U' of the sprocket, this one being an alloy renthal jobby.
Hope that helps
Buz
