Rebuilding Standard KR1 FORKS for track use
blanc
Post by blanc »
Hi all
Turning my 88 KR1 into a budget track bike, going to rebuild my forks using new seals and oil What do you suggest for track use?
To fail is to not to have tried at all.....Push your boundaries!
blanc
Post by blanc »
Scrap that idea. One like a banana . Putting a wanted ad up for kr1s forks.
dave32
Post by dave32 »
nothing wrong with the kr front end,i run the stock setup on the track and its more than capable for trackday use.
if you swap to S forks,which are the same but a different length you will also have to swap calipers,then discs wont fit etc etc.
save yourself the hassle,change the seals and oil and off you go.
blanc
Post by blanc »
Thanks one of them is like a bananna, bought a zxr 250 front end. A friend of mine has come in on the project and he is doing the machine work....phewww =D>
