Posts: 2120 Joined: Sat Jun 09, 2007 10:10 am
Post
by headcoats » Sun Oct 02, 2011 8:35 pm
Gonna need some new ones for the build,does anyone do aftermarket ones ?
Post
by headcoats » Tue Oct 11, 2011 8:29 pm
These have 2 different pitch threads on them,does anyone know what the sizes are ?
Posts: 2055 Joined: Mon Mar 16, 2009 9:33 pm
Post
by Howie » Wed Oct 12, 2011 10:05 am
The 'nut' side is an m10 x 1.25 pitch. Unfortunately all the studs on my spare sprocket carrier are stuck fast so I cannot tell you what pitch is on the other end.
I may have one sitting in my box of bits so I'll have a look a bit later.
Post
by Howie » Thu Oct 13, 2011 1:20 pm
Had a look but no luck.
Best thing to do HC is remove a stud from your carrier then use a known size bolt to see if it screws in ok, unless you have got a bolt pitch gauge?
