unstable timing during start
fuad
Post by fuad » Tue Apr 01, 2014 8:50 am
hi everyone
i newbie and have model KR250A, so my machine unstable condition when start,it take around 10 minute to stable back the engine timing.
my alternative is itake off air filter to make gas move fast to engine during start.
how can i solve this problem?? :cry:
dougindoors
Re: unstable timing during start
Post by dougindoors » Sat Apr 05, 2014 11:52 pm
Sounds like the choke is jammed on check the choke pistons on the carbs are not seized
1984 Kawasaki KR250A
2 Smokey and they bandit
fuad
Post by fuad » Fri Apr 11, 2014 6:17 am
dougindoors wrote:Sounds like the choke is jammed on check the choke pistons on the carbs are not seized
When i pull up choke cable One by one,my engine will off when i pull choke on top carburator engine,its choke piston are not seized??at that carburtor
Thanks dougindoors for your help
fuad
Post by fuad » Wed Jun 11, 2014 10:22 am
from your advice dougindoorsi,i tell my formen and adjust the carb setting and he set up slide to same movement and my main jet to the same size so my machine running well from start and on road condition. :) :D
dougindoors
Post by dougindoors » Fri Jun 13, 2014 9:55 pm
Glad the info helped,go for it another kr back on the road,I will just keep working on mine in between projects, one day she's not loosing any value so I think longer I keep her the more she's worth :D
