Parts Required for 85 KR 250-A2
TurboStew
Post by TurboStew »
Hi guys, I have a KR that I am trying to restore, but finding parts is a little hard. I am in Melbourne Australia and am looking for the following parts:
#RH Side cover that covers the battery.
#cover that fits in fairing to fill hole for radiator cap inspection.
#Engine clutch cover assembly or a cheep guy that can weld repair mine.
#1x front Indicator assembly.
#fuel tank or I will put the epoxy sealer kit through mine.
#Windscreen.
If anyone can assist at good prices I would be very grateful.
Cheers Stew.
(2x) GPZ 750 Turbo, E1 1984 & E2 1985
KDX 175 B2
1997 GSXR 750 SRAD Blue/White
1984 KR 250 A Tandem Twin, Green
1985 KR 250 A2 Tandem Twin, Red
Skyeport
Re: Parts Required for 85 KR 250-A2
Post by Skyeport »
Hi Stew,
I might have some if not all of what you need.
Will have a look in the shed tonight.
I'm in Queensland so a fair way away, might be easier to find parts closer?
Skyeport
Stew welcome to the forum, interesting list of bikes. Good luck tracking down the parts, there is a great support network on this forum and I'm sure folk will be along to point you in the right direction.
James P
Post by James P »
You don't need any throttle cables do you Stew? I've still got these:
viewtopic.php?f=2&t=10988
I've had them for a while now and don't need them. If you're interested, I'll consider an offer!
TurboStew
Post by TurboStew »
James P wrote:You don't need any throttle cables do you Stew? I've still got these:
Thanks James for the reply and offer of your cables. I am good with the cables and kick-start.
Thanks Skyeport for having a look in your shed to see if you can help me with my parts request/list. I will be looking forward to seeing what you got.
Cheers all Stew
KDX 175 B2
Skyeport
Post by Skyeport »
Hi Stew,
Had a look at what I've got in the shed.
#RH Side cover that covers the battery.- Got one but a bit tatty & needs repairing where the bolt hole is.
#cover that fits in fairing to fill hole for radiator cap inspection. _ Haven't got one
#Engine clutch cover assembly or a cheep guy that can weld repair mine.- Got one, bit of a scrape on the outside but appears to be no internal damage.
#1x front Indicator assembly._ do you mean the fairing mounted ones or the bigger ones some came out with? I have some fairing mounted ones that are fairly faded & tatty.
#fuel tank or I will put the epoxy sealer kit through mine.- Got a spare one but with no cap
#Windscreen. -Haven't got a spare one.
I'll try to add some photos:
Skyeport
Post by Skyeport »
More photos:
GreenZX10guy
lurker
Post by GreenZX10guy »
Get a price on shipping of those cables (ex kickstart lever) to South Africa and give me a total price
I may just take them off you
As for spares, I can assist in most of that with the exception of the fuel tank\
only issue is i am in RSA
