Clutch cable available ,54011-1221, but in Japan :(
pepsi
Post by pepsi » Mon Dec 28, 2015 4:09 pm
Anybody in the west try to buy parts from Japan?
http://buyee.jp/item/yahoo/auction/q970 ... n?rc=yaucb
Re: Clutch cable available ,54011-1221, but in Japan :(
Post by Binetta Steve » Mon Dec 28, 2015 10:47 pm
Im sure theres an article on here about buying from Japanese auctions using Jauce? Apologies for spelling. Keep looking back about 3 months im sure it was someone buying Yam LC exhausts
Here it is !!!!!!
viewtopic.php?f=1&t=12796&hilit=Japanese
sulli
Post by sulli » Thu Dec 31, 2015 12:31 pm
Hi there first post have just got a kr250a to restore and noticed about the supersession of parts if you look here http://motor.geocities.jp/tetsuma3ya/kr250_cable.html there is a comparison for the gpz400 clutch cable for a replacement use google chrome to translate our Japanese friend is a wealth of information as to what latermodel parts will fit HTHs Sulli
Located Brisbane australia ;-)
sulli
Post by sulli » Thu Dec 31, 2015 11:25 pm
There is a substitution available a zxr 400 clutch cable is compatible minor differences and should be available locally
http://motor.geocities.jp/tetsuma3ya/ more info available here use google translate to read the page lots of good info regards Sulli
pepsi
Post by pepsi » Sun Jan 03, 2016 12:18 am
sulli wrote:There is a substitution available a zxr 400 clutch cable is compatible minor differences and should be available locally
neat site however the brake master cylinder rebuild photo shows the cylinder internals incorrect, the seal on the spring should be between the piston and the spring. just a little small detail, I know , I would get a hold of the site owner to let him know but I don't speak or type Japanese!
see below
not this
Post by 500bernie » Sun Jan 03, 2016 11:47 am
Hi Pepsi
Are you sure that yours (in the photo is assembled correctly) as the part is common to lots of models and they all show it assembled as per the diagram.
(zx900-a1, 300 ninja 2014 and loads of others including the Kr1s)
It is that long since I refurbished mine that I can't remember what it looked like, I know that I would have reassembled it exactly as it came apart, I will try and see if I took any photos.
pepsi
Post by pepsi » Sun Jan 03, 2016 3:33 pm
500bernie wrote:Hi Pepsi
the photo is from the website showing the assembly wrong, I assembled mine like per the diagram with the rubber between the spring and the piston. I sat up all night trying figure out what was the purpose of the little rubber thingie ( I don't think its a seal) . I think its simply a rubber guide to capture the spring so its piston end does not slide over and start scoring the cylinder bore.
StrokerBoy
Post by StrokerBoy » Mon Jan 04, 2016 1:03 pm
pepsi wrote:Anybody in the west try to buy parts from Japan?
Done it loads of times, never had any problems. I used FromJapan (not recently) but many other middleman services are available now.
がんばって!
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
edd1985
Post by edd1985 » Sat Apr 09, 2016 12:46 am
hola amigo disculpa soy de ecuador
tengo una moto de este tipo y no e podido consegir repuestos me podria ayudar
Bokusouchi_2
Post by Bokusouchi_2 » Sat May 26, 2018 3:59 pm
Hello all
anybody knows the part number of the zxr400 clutch cable that could replace the kr250 clutch cable 54011-1221 .
the link mentioned http://motor.geocities.jp/tetsuma3ya/kr250_cable.html is dead .
There is no mention of "clutch cable" anywhere on http://motor.geocities.jp/tetsuma3ya .
the Problem is that there are several clutch cable part numbers for the zxr400 , depending on the year .
thanks for your help
