need clutch springs ,92081-1821 and plates
pepsi
Post by pepsi » Mon Mar 06, 2017 10:58 pm
Found the plates, but the springs are hard to find ,found these, but they are gonna cost a lot :shock: , are there any other springs I could use?
http://www.ebay.com/itm/232195589212?_t ... EBIDX%3AIT
Gerrit
Re: need clutch springs ,92081-1821 and plates
Post by Gerrit » Mon Mar 06, 2017 11:15 pm
Found this, there may be other suppiers:
http://www.ebay.co.uk/itm/KAWASAKI-KR-2 ... Sw3mpXGkNT
Post by JanBros » Tue Mar 07, 2017 12:55 am
a spring is what it is : just a spring.
any spring with the correct length and diameter can do the job, there is only one type of ordinary "spring-steel". it's strength is solely determined by the thickness f the metal, the number of windings and the diameter of the entire spring. so just look for any springs that correspond or deviate not too much (and to be on the safe side, deviate tougher).
less windings (for the same total length) , thicker metal or smaller diameter stiffen the spring.
pepsi
Post by pepsi » Tue Mar 07, 2017 2:21 am
any spring with the correct length and diameter can do the job, ....
yep, I agree , the trouble is finding that spring, the listings do not give dimensions, and I don't have piles of new different springs to compare to the correct stock unworn length. I cannot find any clutch spring dimension charts either. :(
StrokerBoy
Post by StrokerBoy » Tue Mar 07, 2017 12:39 pm
Loads of people advertising KR250A clutch springs on Ebay (UK), I've not tried any of them though.
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
pepsi
Post by pepsi » Tue Mar 07, 2017 3:38 pm
StrokerBoy wrote:Loads of people advertising KR250A clutch springs on Ebay (UK), I've not tried any of them though.
most don't ship to the USA :| I am going to try to get some EBC springs here but I gotta figure out why there are two numbers for apparently the same spring, CSK010 and CSK10, as I can only find the CSK10 ones sold over here. FYI,it seems that KR1S's use the same springs.
pepsi
Post by pepsi » Tue Mar 07, 2017 5:39 pm
I called EBC and they said the two numbers are the same springs so I ordered the ones available over here CSK10. :D I have a set of OEM plates and EBC springs coming =D>
