front wheel centerline
Posted: Fri Dec 31, 2010 7:17 pm
by pepsi
Hi , Is the front wheel on a KR250 centered (or offset) in the forks?
Re: front wheel centerline
Posted: Tue Jan 04, 2011 1:10 am
by pepsi
pepsi wrote:Hi , Is the front wheel on a KR250 centered (or offset) in the forks?
somebody please give me a measure? [-o<
Posted: Fri Jan 07, 2011 10:59 pm
by madmito
Looks like it's centred.Difficult to measure accurately without removing guard.
Posted: Sat Jan 08, 2011 11:11 pm
by pepsi
madmito wrote:Looks like it's centred.Difficult to measure accurately without removing guard.
can you stick your figure between the discs and forks to feel the gap?
Posted: Mon Jan 10, 2011 9:08 am
by madmito
Disc rotor to fork leg is between 14 and 15mm.I've got four KR's measured them all.Are you missing spacers or are you running different forks?
Posted: Mon Jan 10, 2011 12:05 pm
by pepsi
madmito wrote:Disc rotor to fork leg is between 14 and 15mm.I've got four KR's measured them all.Are you missing spacers or are you running different forks?
I have a non standard wheel that the previous owner installed , that is not centered. I beleive I'll have to correct it .
Posted: Mon Jan 10, 2011 12:35 pm
by StrokerBoy
I wouldn't have expected the rim (and therefore the tyre) to be anything other than centred between the forks. Or the rear one non-centered in the swingarm either for that matter. Wouldn't that give strange handling ?
Obviously, at the hub there are normally different length spacers to cope with the speedo-drive (and the sprocket/cush-drive at the back) but the net result is to centre the tyre surely ?
No doubt someone will be along shortly to point out I'm wrong...
