Page 1 of 16
finally started
Posted: Thu Mar 10, 2011 10:50 pm
by dougindoors
finally started after 2 years collecting parts the story starts[/img]
Posted: Thu Mar 10, 2011 11:41 pm
by StrokerBoy
Nice one Doug, keep us updated. Started doing a few bits on mine last week too.
Posted: Fri Mar 11, 2011 7:18 am
Nice one, that's always a good feeling.
Posted: Mon Mar 28, 2011 3:42 pm
by dougindoors
just a quick line, after sitting in the corner of the garage for 2 years, after purchase as non runner due to suspected crank seal failure and not to sure how long it had stood prior no me obtaining it (at least a boat trip from Aus). put a battery on the old girl, filled the float chambers with mix, 2nd kick fired up and ran for a short while =D> . time to start stripping now. will keep you informed
strip continues
Posted: Sun May 01, 2011 5:59 pm
by dougindoors
opps!!! progress or not
Posted: Wed May 18, 2011 6:26 pm
by dougindoors
opps!! sorry guvnur i was only cleaning it
Engine strip
Posted: Thu May 26, 2011 10:54 am
by dougindoors
well while the frame is being cleaned and repainted i thought it was time to strip the engine to renew the suspect crank seals, I attacked the left side 1st well you have to start somewere, once apart was a bugger to release the crank bearing from the cover ( at least they are a good fit and have not been spinning in the case) i found the seals like new obviously they have been changed,maybe when the piston and barrel was done, also the stator has been rewound, i was suprised to see the internals in such good condition. so lets move on to the right side after a bit of a struggle getting the kick start shaft through the case bearing off it came, wow! new clutch plates seems in a previous life a lot of work has been done here. on removing the crankshaft dampers the problem was revealed, the area the the seals run was very badly pitted and corroded with rust. now what? off to my local engineering shop fo a solution
, machine 1 mm off the damper body and fit an oversize seal. now waiting for the work to be completed
. pics of stripped engine to follow.
crank dampers
Posted: Fri Jun 03, 2011 11:22 am
by dougindoors
well damper back all nice and corrosion free complete with o/s seals 55x40x7, hopefully start reassembing this weekend. frame now at the powder coaters, cleaned both wheels up this week looked lovely, then noticed the front wheel had a ding in it, lucky have a spare set but these had been painted and the smart arse used etch primer. more to follow.
update
Posted: Fri Jun 17, 2011 4:49 pm
by dougindoors
frame should be back tuesday 21st will post pics, engine has been stripped and partially rebuilt, thats when the problems started. bolting the 2 half's of the crank cases together i noticed the cap head bolts were up to torque but not holding the cases together, bolts to long? streched? well out they come again grind off 2mm clean off sealant and refit bolts,now the fun starts, were did i put that shim for the kick start idler gear and the shims for the crankshaft centre gear?
oh! some one didnt fit them last time the engine was stripped. well back to the local friendly engineering shop, 1x 1mm 2x 1.5mm 1x 1.4mm shim and so on hopefully end of next week the engine will be rebuilt. pics to follow
By the way Tim thanks for the manual all those years ago lol. without it i would be knackered, i will give you 1st pickings on all the spares l have over when she's finished.
Re: update
Posted: Mon Jun 20, 2011 11:20 am
by StrokerBoy
dougindoors wrote:By the way Tim thanks for the manual all those years ago lol. without it i would be knackered, i will give you 1st pickings on all the spares l have over when she's finished.
No problem Doug, glad I could help.
By the way, there shouldn't be any bits left over when you've finished.
BITS
Posted: Mon Jun 20, 2011 12:07 pm
by dougindoors
well tim what do i do with all these washers and nuts i have in a box????? i thought they were spare ones as you always get overs when you strip a bike dont you????
Re: BITS
Posted: Mon Jun 20, 2011 1:33 pm
by StrokerBoy
dougindoors wrote:well tim what do i do with all these washers and nuts i have in a box????? i thought they were spare ones as you always get overs when you strip a bike dont you????
Ah, sounds like you're making a lightweight version. It'll be fine !
finally started
Posted: Sat Jul 16, 2011 9:30 pm
by dougindoors
well i told a few porkeys engine now rebuilt sorry no pics, seems the last person did not have a manual. shims ect missing and would you belive the circlip that holds the clutch on not there
well its ready for painting and i will post a pic of the finished item. the frame is back looking very nice, half way through sorting the forks, one pair has good tubes and the other has good outers, so masses of bits on the bench at the mo. and i promise i will post pics
just one thing does any one know if the anti dive is used by any other models i.e gpz's more to follow camera is charged
Re: finally started
Posted: Sat Jul 16, 2011 11:45 pm
by ScottaKR
dougindoors wrote: just one thing does any one know if the anti dive is used by any other models i.e gpz's
Yeah, it was used on GPZ's of the era, but not exactly sure what models.
Sorry, I know that probably dosn't really help a lot.
Posted: Sun Jul 17, 2011 11:16 am
by the KR kid
Had a leaky anti-dive when I got my bike, but fitted Gpz600 seals which fitted ok.
