Kickstarter shaft
saeid
Kickstarter shaft
Post by saeid » Wed Apr 27, 2011 9:12 pm
Previous owner had damaged kickstarter shaft by welding it to lever.
That welded section had to be cut for dismantling the engine.
I used the teeth end section of h***a CG 125 kick starter shaft and had it welded to the remainder of original shaft. To keep the kick lever in place
grinded a groove to put a circlip.
miuganlee
fff
Post by miuganlee » Fri Nov 02, 2012 11:50 am
Good..
