Previous owner had damaged kickstarter shaft by welding it to lever.
That welded section had to be cut for dismantling the engine.
I used the teeth end section of h***a CG 125 kick starter shaft and had it welded to the remainder of original shaft. To keep the kick lever in place
grinded a groove to put a circlip.
Kickstarter shaft
