Page 2 of 3
Posted: Fri Dec 07, 2012 5:21 pm
by Top-shaggy
AR125 disk information here
http://diffrentstrokers.com/phpBB2/view ... f144d2f61e
Sorry couldnt find where i put it on the KR site so link to a different forum but may still be worth a look.
Something like closing the inlet (trailing edge) at 75-85deg ATDC should make a big difference. TSI on this forum may be worth a PM on this one !
Posted: Fri Dec 07, 2012 7:44 pm
by 2stroke
Yeah something to play with
Thanks !
Re: Tuning
Posted: Wed Dec 12, 2012 3:51 pm
by dirk
2stroke wrote: ..... It has NOTHING under 3000rpm.....
Any advice will be helpful
Hi
i know the problem.
this is the solution:
regards
Posted: Wed Dec 12, 2012 7:47 pm
by 2stroke
Nice one dirk
To anyone who maybe interested.
Our result for carby setting was,
25 pilot
150 main
And needle full rich.
Works fine better bottom end power.
Seems to be harder to start but
Posted: Wed Dec 12, 2012 7:57 pm
Dirk's words of wisdom did spring to my mind before you mentioned having to slip the clutch.
What were your jetting settings before?
Posted: Wed Dec 12, 2012 9:32 pm
by 2stroke
Pilot jet was 45
Main 150 after barrels ported.
Needle in the middle
Posted: Fri Dec 14, 2012 11:23 am
What were the carb settings from factory?
Posted: Fri Dec 14, 2012 7:33 pm
by StrokerBoy
Luders wrote:What were the carb settings from factory?
Manual says :
Main Jet 137.5 (range 132.5-142.5)
Main Air Jet 1.5
Needle Jet O - 6
Jet Needle 5DH2-4
Needle Clip Position 4
Pilot Jet 35
Starter Jet 70
Fuel Level 4 +/- 1 mm
Float Height 21 +/- 2 mm
Posted: Fri Dec 14, 2012 8:15 pm
by 2stroke
Have a 150 main and looking at the plug it can still go larger.
Very nice top end power now. Pulls like a 250 should
Posted: Fri Dec 14, 2012 10:31 pm
I would always advise sticking with stock jetting. Glad you''re happier with the power improvement though.
Posted: Sat Dec 15, 2012 9:38 am
by ScottaKR
Luders wrote:I would always advise sticking with stock jetting. Glad you''re happier with the power improvement though.
I would've thought that too till I read this...
2stroke wrote:Main 150 after barrels ported.
Now I understand the reason it was so flat down low in the first place.
Posted: Sun Dec 16, 2012 8:35 pm
by 2stroke
ScottaKR wrote:Luders wrote:I would always advise sticking with stock jetting. Glad you''re happier with the power improvement though.
What are you on about?
We bought this bike with no compression and needing a rebuild. Also no bottom end power.
So we rebuilt in,
Porting the barrels not for top end only but right through the rev range. Which it has done.
O-ring the heads to give higher compression which also improves bottom end.
Bike did improve and goes great.
But comments like yours makes me wonder why I bothered sharing this on here!!!
Posted: Mon Dec 17, 2012 9:04 am
by ScottaKR
2stroke wrote:ScottaKR wrote:Luders wrote:I would always advise sticking with stock jetting. Glad you''re happier with the power improvement though.
So we rebuilt in,
I'm sorry if you took what I said the wrong way, but it was the first time youd even mentioned porting the barrels, let alone how they had been ported. More often than not people will port for massive top end, which is what I had wrongly assumed, but you hadn't really given us much to go on.
Posted: Mon Dec 17, 2012 7:48 pm
by 2stroke
Cool. Just don't judge before you know the facts.
Re:
Posted: Thu May 04, 2017 5:32 am
by pepsi
2stroke wrote: ↑Wed Dec 12, 2012 7:47 pm
Nice one dirk
25 pilot
150 main
I am trying to remove the bottom end bog, and I have lowered the needle from stock, to the third groove,( will cause more lean conditions in low rpm.) will report back ASAP.
