need a new front sprocket
pepsi
Post by pepsi » Tue Jan 08, 2013 10:51 pm
Where can I get a new sprocket for my KR250?
Bogan
Post by Bogan » Tue Jan 08, 2013 11:29 pm
If it helps your OEM part number is 13144-1113 which appears to be shared by the 1987 EX250-E Ninja (according to one Google link I found).
I can't find any other more current models sharing that part number using any of my usual web resources.
Maybe give your local dealer a call and see if that part number has been superseded with something you can order?
Edit: I think you can use one of these:
http://www.jtsprockets.com/catalogue/sprocket/JTF516-13
Measure up the one you have and see if it will fit?
the KR kid
Post by the KR kid » Tue Jan 08, 2013 11:32 pm
RPM have a chain/sprocket kit on eBay. It's in the UK, but might be worth contacting them to see if they'll sell you just a sprocket?
http://www.ebay.co.uk/itm/Kawasaki-KR25 ... 20bcc43e85
GS750B
KH250B5
pepsi
sprocket loose
Post by pepsi » Thu Jan 10, 2013 12:30 pm
I found a supplier ;the old sprocket is loose on the splines, is that normal?
pepsi
Post by pepsi » Mon Mar 25, 2013 9:59 pm
the new sprocket came in wrong so back to the drawing board ](*,)
pepsi
Post by pepsi » Tue Mar 26, 2013 12:56 pm
It seems that they will not sell me a sprocket by itself or they do not have one at all,so their ebay ad might be wrong
the KR kid wrote:RPM have a chain/sprocket kit on eBay. It's in the UK, but might be worth contacting them to see if they'll sell you just a sprocket?
pepsi
Post by pepsi » Tue Mar 26, 2013 12:57 pm
anyone have a good used one? :?
pepsi
Post by pepsi » Tue Mar 26, 2013 1:03 pm
looked it up ,doesn't look the same
Bogan wrote:If it helps your OEM part number is 13144-1113 which appears to be shared by the 1987 EX250-E Ninja (according to one Google link I found).
Post by Top-shaggy » Tue Mar 26, 2013 8:21 pm
May be worth posting some pictures of your old sprocket - it may help us identify another the same.
Just a thought though... Is the old sprocket the right one for the KR250A ? Or has someone used an alternative? ( you say it is loose on the splines, worn? Or not the right one?)
Post by Howie » Tue Mar 26, 2013 8:54 pm
wemoto.com list them,
Kr250a front sprocket, looks like you have a choice of makes too.
There's nothin' worse than a blabber-mouth cat
pepsi
Post by pepsi » Tue Mar 26, 2013 9:16 pm
thats a good question since I have H0nda wheels :-k I'll have to dig into it somemore
Top-shaggy wrote:May be worth posting some pictures of your old sprocket - it may help us identify another the same.
pepsi
Post by pepsi » Tue Mar 26, 2013 9:51 pm
the dimension in this photo "21.6mm" is not correct for our bikes it is 24mm
The dimension in this photo "25mm" is not correct for our bikes it is 28.5mm
we have 12 splines not 13
ozzy1
Post by ozzy1 » Wed Mar 27, 2013 12:22 am
As mentioned these guys are probably your best bet
http://www.wemoto.com/bikes/kawasaki/kr ... _a2/84-86/
Post by Top-shaggy » Wed Mar 27, 2013 1:10 am
ozzy1 wrote:As mentioned these guys are probably your best bet
I would email or phone them first to check
1. It's what your after and
2. They have it in stock
I've used them before and was happy with service :D
ozzy1
Post by ozzy1 » Wed Mar 27, 2013 2:47 am
Nearest i can find to the dimensions you gave is for a GPZ900 but its a 530 pitch.
http://www.wemoto.com/bikes/kawasaki/gp ... eeth_-_jt/
