paint codes
Plastic bits and Paint
paint codes
Hi all this comes from the zxr owners club hope they don't mind, its paint codes for kawasaki.
How do you find the ordernumber of the paint?
You know the color code of your motorbike:
See the following example for an explanation on how you find the right ordernumber.
Example:
You have a Kawasaki and you want to have paint for the color with the code: 7F.
If you look in the list for the line with that description.
You will find the following line:
Spraypaint Aerosol spraycan Touch up pencil Paintnumber Colorcode Color description
39- 88- 13- 2011 7F LIME GREEN
For spraypaint: (Spraypaint can only be applied with a spraygun or a preval sprayer)
You look for the number in the first column under spraypaint.
Optional number
39- A choice from: 1 only a base coating
4 base coating + clear coating
49- A choice from: 1 only a base coating
59- A choice from: 3 Primer + color coating
4 primer + color coating + clear coating
68- a choice from: 3 primer + pearlescent coating
4 primer + pearlescent coating + clear coating
The articlenumber = (Spraypaint) + (Paintnumber) + (Optional number)
So the articlenumber of the spraypaint is 39-20111 for only base coating
So the articlenumber of the spraypaint is 39-20114 for base coating + clear coating
Note!
When using other brands of clear coating you can get a different color.
Using other brands of clear coating is at own risk.
To get the exact color always order spraypaint with clear coating.
For aerosol spraycan: Note down the number in the 2nd column under Aerosol + paintnumber.
Example: 88-2011
* = Aerosol Set
For Touch up pencil: Note down the number in the 3rd column under touch up pencil + paintnumber.
Example: 13-2011
* = Pencil Set
n.a. = not available
If you don't know the color description of your motorbike:
Email or fax us the framenumber and the main color of your motorbike, the color
you wish to order and a description of the part to be painted .
Available colors
Paint Spraycan Touch up Paintnumber Colorcode Color description
68- n.a. 19- 2072 1B PEARL CHROME YELLOW
68- n.a. 19- 2064 1G PEARL CANDY YELLOW
39- n.a. 13- 2128 1M DEEP TURQUOISE GREEN
49- n.a. 15-* 2001 1R LUMINOUS CHESTNUT BROWN
68- n.a. n.a. 2056 1S LIMINOUS TANGERINE ORANGE
49- n.a. 15- 2588 1Z MET. DARK BRONZE
49- n.a. 15- 2266 20 PEARL PURPLISH BLACK MICA
39- n.a. 13- 2102 23 JET SKI VIOLET
49- 72- 15- 2612 218 PEARL MYSTIC BLACK
59- n.a. 18-* 2248 234 PASSION RED
49- n.a. 15-* 2604 235 CANDY THUNDER BLUE
49- n.a. n.a. 2646 455 MET. CRESCENT GOLD ZX12R '02
49- n.a. 15- 2638 458 FRAME PHANTOM SILVER
49- n.a. 15-* 2679 468 METALLIC RUBY RED
49- n.a. 15-* 2661 469 METALLIC COMET BLUE
68- n.a. 19-* 2080 470 PEARL BLAZING ORANGE
49- n.a. 15-* 2653 473 MOONLIGHT SILVER
49- n.a. 15-* 2687 474 GALAXY SILVER TYPE 2
68- n.a. 19-* 2255 660 METALLIC SPARK BLACK
39- n.a. 13- 2144 683 ORIENTAL BLUE
59- n.a. 18-* 2206 2D AMARANTH RED MICA
49- n.a. 15- 2513 32 PEARL ROYAL BLUE
59- n.a. 18-* 2180 35 LUMINOUS PEACOCK BLUE
49- n.a. 15-* 2332 3F MET. MIDNIGHT PURPLE
49- n.a. 15- 2539 4Q MET. CHAMPAGNE GOLD
n.a. n.a. n.a. 5G BLUE PURPLE (WHEEL)
n.a. n.a. n.a. 6F POLAR WHITE
49- n.a. 15-* 2340 75 MET. CELEST SILVER
n.a. 88- n.a. 2011/8 7F LIME GREEN 400ml SPRAYCAN
59- n.a. 18-* 2164 81 CANDY ARSENIT GREEN
49- n.a. 15- 2118 8N CANDY LIME GREEN
n.a. n.a. n.a. 93 MET. MEADOW MIST GREEN
59- n.a. 18-* 2073 A5 CANDY PERSIMON RED
49- n.a. 15- 2159 A8 LUMINOUS NAVY BLUE MET.
39- 88- 13- 2003 B1 FIRECRACKER RED
n.a. n.a. 13- 2045 B1 FIRECRACKER RED HELL
49- 72- 15- 2274 B5 BLACK PEARL
49- n.a. 15- 2027 C4 GRAY STONE MET.
49- n.a. 15-* 2123 C6 MET. NOCTURNE BLUE
59- n.a. n.a. 2230 D2 LUMINOUS RUBY RED
49- n.a. n.a. 2570 D6 ROYAL DARK RED
59- n.a. n.a. 2222 D9 LUMINOUS PASSION RED
39- n.a. 13- 2052 DB BLUE 24
49- n.a. 15- 2282 DH COSMIC GRAY MET. (WHEEL)
49- n.a. 15- 2225 DS LUMINOUS WINDSOR GREEN
59- 75-* 18-* 2214 E1 CANDY LIGHTNING BLUE
68- n.a. 19-* 2049 ED COSMIC SPLENDER RED
49- n.a. 15- 2084 EE BRONZE GUNS MET.
49- n.a. 15- 2258 EZ COSMIC GRAY (FRAME ZEPHYR)
49- 72- 15- 2019 F2 GALAXY SILVER
39- n.a. 13- 2110 F8 JET SKI VIOLET (WHEEL)
49- 75-* 18- 2032 FC CANDY ATLANTIC BLUE
n.a. n.a. 15- 2175 GA MET. CANYON SILVER
49- n.a. 15- 2167 GD GENTRY GRAY MET. (FRAME)
49- n.a. 15-* 2562 GU MET. PHANTOM SILVER
n.a. n.a. n.a. GV COSMIC SUPER RED
49- n.a. 15- 2100 GW METALLIC SONIC BLUE
39- n.a. 13- 2037 H1 SUNBEAM RED
59- n.a. 18-* 2008 H3 CANDY WINE RED
59- n.a. n.a. 2156 H3 CANDY WINE RED (GPZ500S '94)
39- 88- 13- 2029 H8 EBONY
59- n.a. 18-* 2040 HB LUMINOUS ROUGE
59- n.a. 18-* 2057 HC LUMINOUS ROSE OPERA
49- n.a. 15-* 2142 HT OPAL SILVER
59- n.a. 15- 2065 JW METALLIC VIOLET ROYAL
49- n.a. 15- 2126 JZ METALLIC EVENTIDE
59- n.a. 18-* 2107 KD BLUE 36
49- n.a. 15- 2241 KF FLAME SILVER NO. 30 (FRAME)
49- n.a. 15- 2134 KH METALLIC BLUE GITANE
39- n.a. 13- 2094 KT DYNASTY GREEN (FRAME)
59- n.a. 18-* 2024 L1 CANDY CARDINAL RED
59- n.a. n.a. 2016 L2 CRIMSON RED (VN1500)
n.a. n.a. 18-* 2081 M4 LUMINOUS POLARIS BLUE (GPZ500S)
49- n.a. 15- 2035 M4 LUMINOUS POLARIS BLUE
49- n.a. n.a. 2092 M4 LUMINOUS POLARIS BLUE HELL
59- n.a. 18-* 2099 P5 LUMINOUS VINTAGE RED
39- n.a. 13- 2136 Q6 DEEP GOOSEBERRY
68- 76-* 19-* 2007 R1 PEARL ALPINE WHITE
59- n.a. 18- 2131 RK CANDY SUNGOD ORANGE
49- n.a. 15-* 2521 RL PEARL GREENISH BLACK
68- n.a. 19-* 2023 SD MET. BLUE VIOLET
49- n.a. 15- 2308 SL PEARL CHATEAU GRAY
49- n.a. 15-* 2191 SM PEARL TEAL GREEN
49- n.a. 15- 2050 T2 PEARL COSMIC GRAY
49- n.a. 15-* 2043 T8 PEARL GENTRY GRAY
49- n.a. 15- 2183 TX FRAME SILVER NO.35
39- n.a. 13- 2086 TY FRAME VIOLET
49- n.a. 15- 2505 U5 PEARL JADE GREEN
n.a. n.a. n.a. UI MET. CREMONA OLIVE
49- n.a. 15-* 2217 VG PEARL BOULOGNE (GREEN METALLIC)
49- n.a. 15- 2620 V5 SILVER (WHEEL ZX6R)
68- n.a. 19-* 2031 VH PEARL GALAXY MICA (BLUE METALLIC)
49- n.a. 15- 2233 VV JUPITER GRAY MICA
n.a. n.a. 15- 2068 W4 GENTLY GOLD MET.
49- n.a. 15- 2596 X8 PEARL BURNISH BEIGE
59- n.a. n.a. 2149 Z1000/900 GREEN MET.
59- n.a. n.a. 2198 Z1000 '76-'78 RED MET.
30- n.a. n.a. 0105 ZXR750 '93 NEON PINK
49- n.a. 15- 2324 MOTOR ZX6R DARKGRAY MET.
49- n.a. 15- 2316 MOTOR GPZ1100 '95 DARKGRAY MET.
49- n.a. 15- 2547 MOTOR ZX 6/9/12 FROM '98 BRONZE MET. MATT
n.a. n.a. 15- 2554 MOTOR ER5 GRAY MET.
49- n.a. n.a. 2290 ZZR 1100 '94 (BLACK/RED).
n.a. n.a. n.a. GRAY METALLIC '73.
n.a. n.a. n.a. 750 H2 '72 + '73.
49- n.a. n.a. 2646 ZX12R '02 METALLIC CRESCENT GOLD
49- n.a. 15- 2547 ZX9R FROM '98 MOTOR BRONZE MET. MATT
49- n.a. 15- 2547 ZX6R FROM '98 MOTOR BRONZE MET. MATT
http://www.zrxocboard.com/board/showthread.php?t=19724
