after finally getting the b2 on the road now having a mare getting the thing to fire into life !
fuel flows freely from tap when turned to prime , good spark coming both plugs and both leads ,
plenty of juice in tank and tried with stand up in case of faulty switch , cleaned plugs and the carbs recently cleaned in the ultra sonic tank
most be something simple I hope , ideas ?
starting ?
Re: starting ?
did you check your side standard swich?
that coult be a problem.
choke cables?
airscrew? ( from the carbs)
ignition lock ( check the wiring)
powervalves are they correctly installed.
choke cables?
Re: starting ?
Tank breather blocked?
Open the tank cap and then try it.
BM
BM
GWB KR1s C2 - Now gone
GWB KR1 - YES IT'S DONE!
ZXR400L PROJECT
AND NO S****Y H****A'S
Usque Ad Mortem Bibendum
ZXR400L PROJECT
- Binetta Steve
Re: starting ?
Silly question you are not flooding it are you? . Best way to start my C 3 is prime , full choke, dont touch throttle , fires 2nd or 3rd kick. Tweak the throttle and ive been at it for 30 or 40 kicks!
- Newbie
Re: starting ?
Cheers for the quick response after whipping the carbs off yet again float heights good , aircrews set , clean jets etc then took fuel pipes off carbs and connected up to tank turned to prime only to find virtually no fuel passing through striped all pipes off t splitter and fuel filter only to find one outlet on filter had got kinked and fuel was not passing freely back together fired on second kick happy now !
