balance shalt
bezisbird
lurker
balance shalt
Post by bezisbird »
Hi I raced a kr1s at mablehorpe sandracing club last season. Is the balance shaft worth taking out to make it rev up faster .
Also lightening the flywheel any major differences thanks bezisbird..
Re: balance shalt
the balance shaft is in it for a reason, leave it in :idea:
Re: balance shalt
Post by scooble »
there was talk about this in the early 90's, I believe Stan Stephens done it a few times, but he later said that it isn't worth it as it can seriously affect reliability, but skimming the flywheel was also a common mod
Re: balance shalt
Don't do it, you're better off getting a KX125 flywheel machined to fit and add a second pickup to do away with the wasted spark.
yatasaki
Re: balance shalt
Post by yatasaki »
don't do it
when you hold the steering feels like 1000 volts passing through your hands
Professor
Re: balance shalt
Post by Professor »
Lightening the flywheel gives you better response / acceleration but at the cost of less torque.
Don't forget to check the balance after lightening
Hardcore you know the score
