Balance shaft rebuild?
Joe439
Post by Joe439 » Wed Feb 28, 2018 11:32 pm
Is it possible to rebuild the balance shaft with a new bearing and seal?
"If it ain't smokin it's broken!"
"Silence! I kill you!"
Current Bikes: RGV250 vj22 RG250 mk3
NSR 250 mc21
KR250B TZR250 2ma TZR250 3XV
TZM150
Gerrit
Re: Balance shaft rebuild?
Post by Gerrit » Sat Mar 03, 2018 1:53 am
I believe BDK can rebuild a balance shaft should it be necessary.
Joe439
Post by Joe439 » Fri Mar 16, 2018 5:47 am
Yes it is needing rebuilding since rebuilding the engine, does anyone know what the bearing and seal part numbers are?
NSR 250 mc21
TZM150
Post by Binetta Steve » Fri Mar 16, 2018 11:31 am
Not sure if this helps you. I have never done one , but had this page book marked in the past
http://www.pjme.co.uk/acatalog/Kawasaki ... m_End.html
https://www.cmsnl.com/kawasaki-kr250c3- ... ml#results
Joe439
Post by Joe439 » Fri Mar 16, 2018 5:58 pm
Yeah those links I've seen still doesn't give me the info I'm after somebody's got to know. What seal and bearing to use on it.
NSR 250 mc21
TZM150
James P
Post by James P » Sat Mar 17, 2018 4:38 am
Joe,
See my reply under a previous topic: http://kr-1s.co.uk/forum/viewtopic.php?f=1&t=13790
You could modify "normal" 6303-C3 bearings and you could also perhaps use a 23-47-7 seal with a 0.7mm spacer.
Let us know what you end up doing!
Joe439
Post by Joe439 » Thu Jul 12, 2018 3:42 am
Went with the one offered through bdk.
NSR 250 mc21
TZM150
