Nasty low frequency vibration
Took the Kr1s last friday , best day of the year , that ended in tears!
After appx 6 miles engine realy warm gave it full throttle , fine in 3rd 4th power dropped , pulled clutch in , but not seized just vibrating! Realy low frequency "drumming" feeling through bars and footrests. Limped home. Power down but ran ok and started and stopped, but tickover lumpy with revs holding at 3k
Got it home checked following
Plugs fine , rich tea biscuit colour
Dropped gearbox oil , clean no swarf
Small spots of oil on spannies, lube is getting through.
Took stator/ alternator cover off, flywheel really hot, like twice as hot as exhausts after 30 mins, strong smell of burning
No play on flywheel
Next step to remove flywheel and look for any damage.
Then barrels off and look to see if a ring has nipped up
Any thoughts what this could be
Sounds like a bearing in the crank
Is there any play if you try lifting the flywheel
Garry thanks for reply, in short no, the flywheel feels solid no up or down or side to side. It baffles me. Even today 2 days on the plastic alterator cover smells of burning. My pal thinks it maybe a bearing, maybe its the post winter strip!
if top end ok, could be as gary says, bottom end, bearing
Plan is over next week , have a good look at everything , including top end. Ill post news on here Martin
Any other ideas as to what my woes are shout up!
Cliff
Post by Cliff »
Engine to frame bolts tight?
I'm thinking crank bearings too. Maybe conrod big-end bearing.
daz680
Post by daz680 »
The strong smell of burning could be the stator windings on the way out, Ideally you need a mega to test it. as for the vibration have you checked the balance shaft is aligned correctly. If the stator is on the way out or has actually burnt out it could affect a lot of electrical components including the CDI and regulator which in turn would effect the running.
Cheers guys for the suggestions. No news yet as bike is in the shed awaiting my pal who has more confidence than me to start to pull it to bits.
I hope it could be loose engine mounts, but in my heart of hearts doubt it.
Stator damage maybe visible and could explain the realy hot flywheel but the £££££ imact on that is awful to think of.
Bearings will be our first port of call
Positivly the weather in lancashire is awfull so im not pining to be out on the roads.
I will update and probably ask for more guidance as the motor dissembly starts.
Post by SP_BOTT »
Luckily I didn't find it with mine, but could the vibration be the infamous broken frame lug/bracket? Easier to check before removing the engine, otherwise the crack closes when tensions removed.
Hi good point which bracket fails , i had a quick look under the motor the other day when i read about Wills problems. Sorry for the ignorance but putting it simple is it rear right front left , by sidestand etc.
Thanks in advance
It's the rear ones that crack Steve. Although I doubt that this would be the source of any vibration whatsoever, it's still an issue you want to keep an eye out for all the same.
dave32
Post by dave32 »
I had a hairline crack in the left side lower bracket,it felt like the main bearings had gone,lots of vibration when riding through bars and pegs.
You should be able to see the crack,normally go on the left side and its where the bracket meets the frame.It will be harder to see when its NOT in tension as it will close up again.
Stator getting hot wont have anything to do with it,left side mains could have been running dry and transmitting heat outwards or the stator windings are overheating,but they normally pack up on KRs and just dont work.
dave
Well been cleaning under the bike today, didnt realise how many nooks and crannies there were. No signs of hairline cracks , unless i use dye penetrant i dont think im missing anything. Orderd puller for flywheel, first step, is to try and work out where heat came from
Ill post updates as i go along, unlike all the builds on here that get better and shiny (Teerex & Bernie) i seem to be digging a blo..y big hole !
daz680
Post by daz680 »
Hi Steve
hope you've got something to hold the flywheel while you take the bolt out
http://www.ebay.co.uk/itm/380454027221? ... 1439.l2649
