RHS carburator
RHS carburator
Post by jarno » Mon Apr 15, 2013 8:52 pm
cleaned my carbs today because the rhs was leaking
put them in the ultrason and checked everything(floothight etc)
the rhs is still leaking checked it and rebuild it about 7 times today but stil leaking. ](*,) ](*,)
what can it be?
banditbob
needle
Post by banditbob » Mon Apr 15, 2013 9:01 pm
Hi Jarno check the float needle!!!
dave32
Post by dave32 » Mon Apr 15, 2013 9:21 pm
Leaking from the over flow pipe as in flooding?
If so check float height and as said that the needle valve is working and not sticking.
dirk
Post by dirk » Mon Apr 15, 2013 10:36 pm
Hello Jarno
I know that ...
For me it was the seal of the float chamber #-o
Greetings!
Post by jarno » Tue Apr 16, 2013 7:39 am
thanks guys
i did check the floatneedle and it looks ok to me.
wil check it again today.
it is leaking thrue the overflopipe.
Post by Luders » Tue Apr 16, 2013 8:33 am
If it's coming from the overflow pipe check your float needle again.
I had this problem with them sticking and you could take them out and give them a clean, but would start pissing fuel out again after a while. I ended up replacing them and have not had this problem since.
Post by jarno » Tue Apr 16, 2013 10:46 am
thanks luders.
sorted problem is gone.
cleaned the fload needle again now it stopped \:D/ \:D/
