engine bolts
Need some bits ask here
engine bolts
Post by SP_BOTT » Mon Jan 30, 2017 7:09 pm
Hi, looking for both engine mounting bolts, and probably the spacer as well, if anyone has both for sale??
Bought it in bits and didn't realise they were missing :)
bozbridge
Re: engine bolts
Post by bozbridge » Wed Feb 01, 2017 10:36 pm
Can't help with the bolts but I know mine has a non-genuine (likely home made) upper engine bolt, sizes are in the parts catalogue:
M12 x 135
M12 x 282
I think the upper on mine is a piece of 12mm rod threaded at both ends, then they've welded and re-ground a nut on one to make it look like a proper bolt.
Re: engine bolts
Post by SP_BOTT » Thu Feb 02, 2017 9:54 pm
Thanks, think I'm sorted now, would you believe it, a complete set just been listed too, prefer original bolts rather than rod as they are high tensile. Also NLA from what i've found whilst searching.
