KR1-S 28mm Std carbs wanted
Need some bits ask here
russell
Post by russell » Mon May 22, 2017 6:16 pm
As it says above
Re: KR1-S 28mm Std carbs wanted
Post by fred » Fri Jun 09, 2017 12:23 am
i was chatting the other day.their is some very good copies around but you will need to source the internals ,i can`t remember the make,oko i think ,about £80 pair new
russell
Post by russell » Fri Jun 09, 2017 8:37 am
Thanks for that
Post by fred » Fri Jun 09, 2017 10:53 am
Ring Del 012-856-55775,he fitted some because of float needle valve problems and constant flooding on a standard pair, and fitted these oko's ,but swapped all the inners over
