KR1 (1989) Nearly done
There she is!
Just need track body work petrol, oil, new tyres, discs and new rev counter, renthal grips.
Let me know what you think,
Also im going to respray the bike myself with the race fairings i want black green and white so if you have any ideas for a paint scheme please speak up.
Bought my baby for £400 and the engine is sweet as a nut, its basically cosmetics. also the wheels are nearly new
Let me know what you think, also let me know about paint schemes
Thanks
23, Racing a zx9r in Aintree race club.
Ex Kr1 owner.....one day again.
Hell, it looks like a good start to me.
At least yours runs
Are you just going to keep it stock, or are you going to mod it as you go?
As for paint schemes, I got no Idea.
Good luck mate
At least yours runs
Good luck mate
Cheers Scott.
aye it does run, veyr sweet, very reliable!
Also Il be keeping stock long as possible apart from paint, bodywork, tyres then when i start racing il start to get stage 1 tuning moving up the way but reliability is more important atm
Cheers, Il keep posting pics on how far i get
Matty#21
Matty#21
looks good matty, i dont blame you for concentrating on the cosmetics as the motor sounds good from what you said. i would be tempted to source another motor and rebuild it ready to swap should anything happen, especially if yer gonna race it. while your at it instead of going mad on tuning just get crank rebuil/pistons/rings etc and do minimal work yourself rather than pay for work you can do easily yourself. changing port heights/radical tuning that requires special tools/tuner is not neccesery and a stage 1 as you put it is simply cleaning up the ex port, getting rid of casting flaws/sharpen up the webs between the transfer tunnels/match the ex port using a ring of the same diameter as there often out by a considerable amount(enough to see if you look for it) match cases to barrels(not sure if it does anything but doesnt hurt) andf you can flow the cases, how much is up to you but at this stage i would strongly reccomend you keep it minimal for now, use epoxy at a later stage. mj did a thread on all the above inc pics and as a pure kr guru he will explain it much better! do a search on flowed cases. ill find the other thread for you. all the work i have done is based on the hard work mj has done in developing the kr motor to make good power and TBH i have done far more than my ability on track deserves but my naff lap times aside the motor is impressive and aswell as speed it pulls very well from low down, all thanks to mj. i should have saved time and done the above really as this is a good improvment over stock. go to engine section and the thread i mean is titled ''matching barrels''
Cheers fellas, il have a look shortly, ive got all the body work i already have sanded down, just need to get a tack cloth and primer and will be ready to rumble,also when i turn 16 next year(may)i will hopefully becoming a paint and body technician so when im used to it(new job)il do any paintwork anyone needs doing.
Btw what should i do about rearsets atm even though im 6ft 1?
thanks
Matty#21
thanks
Matty#21
The best thing really is to make your own. Mine are further about 120mm further back and 30mm higher than standard and use h***a RS250 GP footrests. You may well need your pegs somewhere different as your a fair bit taller than me, but once you know where you want them its just a case of getting some brackets knocked up.Matty21 wrote:Btw what should i do about rearsets atm even though im 6ft 1?
thanks
Matty#21
The only problem is the gear change mechanicals. I used a Bandit gearlever, bored out to sit on a KR small end bearing with a spacer to compensate for the difference in lengths. I then made a length of bar to extend the arm and used the old lever point as a pivot point with a gearbox end selector on the end where the old gear lever sat. From there to the engine I kept as standard. Took me about 3-4 hours to make it all and I'm very happy with it. It's altered the riding position and it's now more head down arse up.
If I remember I'll post some pics up tonight.
Quick photo of my rearset.
Yep you can but there is a limit on how far you can move it and maintain a decent riding position. Also as the gearlevers are NLA, finding a way of fitting something different means no nightmares if you drop the bike.
Tried a h***a RS front faring on mine and its too tall. So I ended up selling the darn thing. It just never fitted right or looked right.
