new to the site and new prodject ,so hello and help
upyourkiltbatman
Post by upyourkiltbatman »
just got my hands on a F reg kr1 or kr1s not sure which one and its using water somewhere ,had a look at the oil level screen and it doesnt seem to be milky would it go into crank ? or gear box ,not sure as i am used to enduro/motocross bikes .any way i can tell ,off roaders its usualy water pump shaft/seal ,headgasket or cracked head is it the same on the kr1/s any help appreciated thanks :^o
the-elf
Post by the-elf »
There is a hole in the crankcase behind the pump which is supposed to stop the water getting into the box should the waterpump seal fail (not always the case as they can bloke up).
Other things that can cause water loss is a blown head or base gasket allowing water into the cylinder or out of the engine. or a leaking temperature gauge sender.
The worse case is a cracked cylinder/head (not very common on a standard engine).
upyourkiltbatman
nice one elf , it was the head gasket that was the problem so i have just spent two hours with a flat piece of iron and some valve grinding paste , flattening the barrels and head ,should be ok now , just wanted to know why there is two base gaskets on each side ? plus has anyone seen or drilled a hole in there oil filler cap on the clutch (mine has been ) any idea why . cheers
mj43
Post by mj43 »
Drilled filler cap is a sure sign it is an ex race engine.
Two base gaskets probably mean the squish was a bit tight on a single gasket.
upyourkiltbatman
why do they drill it for ? also it has 2.00 oversize pistons is this a good thing , never had it going right since i have bought it due to head gasket
the-elf
Post by the-elf »
upyourkiltbatman wrote:why do they drill it for ?
Race regs say it has to be lock wired into place.
upyourkiltbatman
why does it have to be drilled right through and not just through the top . nothing to do with releaving any pressure ? also because the barrels are 59mm and the head gasket is standard do i have to modify the gasket so there is no overhang ?
mgtkr1
Post by mgtkr1 »
is the cap drilled through vertically???? oh dear, if you mean what i think you mean then a previous bodge artist has indeed thought for some reason that the gearbox needs a pressure release/breather!!!!!! i can only assume the crank seals have failed and sir bodgealot wants to keep her running.
if the drilling is how elf describe then this is purely a safety requirement needed for race scrutineers. prevents the cap coming loose and leaving oil everywhere. i hope its the latter. have never seen anything like the former but this can only mean one thing.
upyourkiltbatman
if it is the crank seals and i put a new oil cap on would this then maybe blow somewhere else ?
mgtkr1
Post by mgtkr1 »
yes, out the crankase breather among other places. it could also start burning gear oil. could ypou post a pic of the oil cap??
