I think the fairing works really well =D> .
gp look not long now
spannerman
spannerman
- scooble
- pablo
Ade forgive my ignorance but
is the reason for fitting the RS swinging arm just cos its a braced item and will improve the ride.I ask cos as far as I can see you've kept the geometry the same as far as the shock mounts are concerned,but is there a difference in the swing arm pivot to the rear wheel spindle distance/angle.
It looks mint anyway
THE FLUTE
I did the same with mine to keep the rising rate and geometry the same as satndard so it rides the as before. Reason for the change is most likely same as mine LOOKS 1000 TIMES better than standard onepablo wrote:Ade forgive my ignorance butis the reason for fitting the RS swinging arm just cos its a braced item and will improve the ride.I ask cos as far as I can see you've kept the geometry the same as far as the shock mounts are concerned,but is there a difference in the swing arm pivot to the rear wheel spindle distance/angle.
spannerman
