front wheel centerline
pepsi
Post by pepsi »
Hi , Is the front wheel on a KR250 centered (or offset) in the forks? :?:
pepsi
Re: front wheel centerline
Post by pepsi »
pepsi wrote:Hi , Is the front wheel on a KR250 centered (or offset) in the forks? :?:
somebody please give me a measure? [-o<
madmito
lurker
Post by madmito »
Looks like it's centred.Difficult to measure accurately without removing guard.
pepsi
Post by pepsi »
madmito wrote:Looks like it's centred.Difficult to measure accurately without removing guard.
can you stick your figure between the discs and forks to feel the gap?
madmito
lurker
Post by madmito »
Disc rotor to fork leg is between 14 and 15mm.I've got four KR's measured them all.Are you missing spacers or are you running different forks?
pepsi
Post by pepsi »
madmito wrote:Disc rotor to fork leg is between 14 and 15mm.I've got four KR's measured them all.Are you missing spacers or are you running different forks?
I have a non standard wheel that the previous owner installed , that is not centered. I beleive I'll have to correct it . :?
StrokerBoy
Post by StrokerBoy »
I wouldn't have expected the rim (and therefore the tyre) to be anything other than centred between the forks. Or the rear one non-centered in the swingarm either for that matter. Wouldn't that give strange handling ? :?
Obviously, at the hub there are normally different length spacers to cope with the speedo-drive (and the sprocket/cush-drive at the back) but the net result is to centre the tyre surely ? :?
No doubt someone will be along shortly to point out I'm wrong...
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
