exhaust mount bottom bracket
- pablo
I'm approaching the point where I'll be mounting the exhausts and I still hav'nt solved the problem of the bottom mounting bracket.
When I stripped the bike,the bottom mounting bracket fell apart.Both anti vibration rubbers fell out of the steel frame.One is OK'ish and might go back in the other was a write off.
At the time I found out they were NLA and could'nt find a used one.So I decided to repaint the carrier and fit it as I rebuilt the rolling chassis.Thinking that the bushes would be a standard size and available from a bush manufacturer and I could replace the bushes at a later date.
Only I can't find them anywhere inspite of some intensive searching.
Anyone else solved this problem.
SP_BOTT
- Howie
- the-elf
I had the same problem. This is going back in the depth of memory but IIRC RS sells rubber compound and it was a simple job mixing it up and making a new rubber between the original steel inner and outer.
- pablo
Elf thanks for that but that rubber compound is a bit expensive in'it
I still hav'nt ruled out making my own
but in the meantime.
I emailed a company that do this sort of thing and they said,they could make two for £15 each but the cost would drop significantly for 10.I don't know how significantly but before I get back to them I was wondering if there where another five or more interested parties.
SP_BOTT
- pablo
- KR1 Man
KR1 Man calling, yes please, count me in for a pair. I have the same problem with my exhaust mount bracket, both bushes are in the same state. Have managed to refit them,but how long they would stay in, I'm unable to say as the KR2 still has a long way to go before reaching that stage. I anyone finds a source or is planning to get some made up then I'll definitley have a pair. Best regards, KR1 Man
- SHimmer45
- Site Admin
This might work:
http://www.grommets.co.uk/bushsta.html
have a look for part number RB250-80-80
Al
Al
- twostrokesmoker
- twostrokesmoker
Got the following mail back today from www.grommets.co.uk
Hello
Thankyou for your enquiry.
RB250-80-80 - MOQ 100 off @ £0.60 each
Carriage £9.50
Material - black Natural rubber
Sorry, we don't send out samples for minimum quantity orders on non technical parts.
Bob Wells.
Do we have 100 knackered exhaust brackets in the club
Hello
Carriage £9.50
Bob Wells.
