the heads are low profile so the shoulder gives a bit of space for the socket recess
on a technical note, the shoulder carries SHEAR force from the rotor to the hub.
The threading process causes stress raising effectively weaking the design (of a round bar)
so the best design is a thicker shoulder carrying the shear not across the threads...
...however alot of standard (older) Yamaha ones (and BMW, some h***a front and Aprilia, Ducatis - see Probolt profiles)
have NO shoulder and have no problems
but if you had the choice why not stainless - rotor bolts are in a corrosion prone area - seized rotor bolts is common problem
http://www.tastynuts.com/file.php?filen ... _Bolts.pdf
if you use Probolt theyre on £4.39 each
cheaper than Ti
