1/ does anybody know the volume of an original KR1S combustion chamber ?
2/ has anybody ever cutted a cylindre head right through the sparkplughole to find out how thick the metal above the comb. chamber is ?
3/ what would be the maximum you can take off (the combustion chamber).
I'm trying so save a pitted cylindre head, but had to scrape off about 1.5mm before the last pit was gone. still usable or would it become too thin ?
some questions ...
some questions ...
head combustion chambers
2/
chamber is 8-9mm thick (approx. perpendicular to chamber contour)
thickness of material (the outer shell) of head itself (above water passages) is only 3.5-4mm
Re: head combustion chambers
I guess 6.5-7.5 will be thick enough ?KR-1R wrote: chamber is 8-9mm thick (approx. perpendicular to chamber contour)
