Fairing repair
Plastic bits and Paint
Fairing repair
here is my effort
looks good.
did you glue them together ?
Hi jan yeah i did glue them, i used mitre glue, it goes off in seconds when you spray the activator on, i used pop rivets just under 2mm for the rods glue it all up then spray quickly pushing together and seems to be holding well, giving it some flex to and still holding cheers.
Brilliant stuff tes,
I had thought about using pins for re-attaching (is that how you spell re-attaching?) my fairings ear, but I wasn't sure how the heat would affect the pins.
I'm kinda thinking about waiting now to see how tescr500's repairs get on before I commit to re-painting my fairings.
I've got all winter \:D/
Hi Howie just hope the glue holds but shouldn't flex to much with the extra strength from pins only time will tell but that will be a while yet at least this winter, also here is what i did with the side cover openings on the fairing, heat a washer up then melt it in be very careful using the heat gun, got the indent i wanted then glued washer in place seems like a nice strong hold.
Nice job Wayne =D>
Are you taking orders yet for fairing repairs [-o<
That's incredibly neat work there fella =D>
I have to do a similar repair to my seat unit. One of the fixing points is missing altogether & the other has about 4 cracks in it.
Part of me wants to say bugger it, go & get a fibre glass fairing! Then I think nah originals look better, probably :-k
Keep those pics coming, you're keeping me going with mine :D
thanks for the comments and im pleased so far, got a few more parts to add when ive done just to strenghen things up a bit, as for my seat unit its in a bit of a mess to, but i will have a go and see what the out come is and post if its good cheers wayne.
Post by Bertie_Mollie »
Yes, well done Wayne =D> =D> =D>
You are making really good job of some tricky repairs.
Keep it up, I'm enjoying watching the transformation.
Andrew
GWB KR1s C2 - Now gone :-(
GWB KR1 - YES IT'S DONE!
ZXR400L PROJECT :shock:
AND NO S****Y H****A'S
Usque Ad Mortem Bibendum
Cheers Andrew
Post by 666damned »
v.nice work indeed..... 8)
cheers 666damned
well thats the last of the repairs and beefing up the holes, bit of filling and hrs of rubbing down then some primer woo hoo.
SP_BOTT
Post by SP_BOTT »
I like it =D> what have you done with the washer repairs, melted one on or used some type of 'top hat' bush, like the ones people use on the caliper conversion, or just a bit of pipe??
Gonna do that to mine next, (when I get the secret :)) I've done a few inspection panel repairs, as well as fairings etc so far.
Hi SP-BOT its no seceret all the small ones are m5 allen key head drilled out to 6mm then ground down to 3mm, the side fairing mounts are the same but m10 drilled out to 12mm and cut back to 7mm, the side fairing covers is just a m8 washer drilled out to 9mm heated up with heat gun to start melt in, then heated in the fairing but be careful as the plastic does go a bit like jelly just squash it in a bit at a time, hold something flat on the other side as not to mishappen to much, all of these are glued in with wickes mytre glue which is pretty dam good, bit of plastic padding of the top i don't reckon you'll even see it, besides once all bolted up will be hidden anyway, i think ive covered your question, but if i can be of anymore help your more than welcome to ask cheers wayne
ALL STAINLESS STEEL TO.
