Mitaka and Vertex Pistons DT 125
maccas
Post by maccas »
Mitaka pistons have a similar sized cut-out and people don't seem to have a problem with those. The same goes for 3mas running mitakas too.
I know what you mean though lozza
mj43
Post by mj43 »
Mmm... My TZ pistons don't have that problem and I have fitted buttons in the piston pin holes this year to stop the short circuiting Lawrence mentions.
I have been led to believe that Aprilia do likewise on their Motors?
TwoStroke Institute
Post by TwoStroke Institute »
mj43 wrote: I have been led to believe that Aprilia do likewise on their Motors?
But short circuiting is not the main reason :-# :lol: :lol: :lol:
crochet & croquet
Rocket
Post by Rocket »
what do you mean by " short circuiting"
Rocket wrote:what do you mean by " short circuiting"
the cutaways in the DT125 piston are so big, that when they are at the level of the boost/transfer ports they create a bridge between them. That way there is a direct connection between the exhaust and the cranckase when there isn't supposed to be one :wink:
Professor
fitment
Post by Professor »
I'm just trying a pair of Wossener KDX pistons, I've cut the skirts slightly to match bottom of the barrels / original pistons.
The lube holes aren't quite in the right place though so they open to the exhaust port briefely!
Look ok otherwise so I'm going to try them
Hardcore you know the score
mj43
Post by mj43 »
Mark as Jan says the indents on the side of some pistons can allow gas from the transfer and the KIPS port to mix or escape.
The problem is not confined to just the piston indents, even if you have a piston with no indent in front of the piston pin, the piston pin hole sits across the KIPS and Front Transfer port. From memory a 'short circuit' occurs for 12mm of piston travel - 25% of the stroke.
"Made many cheap and cheerful pin plugs from balsa and JB Weld, much to Frits' dismay Worst that can happen is it falls out and gets burnt and disappears into the exhaust. A kart motor that got a slight bit of deto showed no residual traces of the plugs. "
http://www.kiwibiker.co.nz/forums/showt ... er/page424
the above Kiwibiker thread is a mix of fact and fiction - but there is discussion of gudgeon pin plugs around page 424 - you need a login to see their photos though
Professor
running
Post by Professor »
I've just got my engine running with kdx pistons in. not ridden it yet but started up ok. A bit fluffy off idle but that could be carburation.
Re: fitment
they should be in exact the same location :-k
has your exhaust port been widened ?
TwoStroke Institute
KR-1R wrote:.
Certainly has taken a life of it's own, like a black hole it's sucking in every 2T enthusiast in the world.
crochet & croquet
Re: running
Professor wrote: Image
picture on the forum of a KR1 cylindre. you can see clearly the side of your port doesn't go straight down, so it must have been widened bye someone who didn't know what he was doing ](*,)
Professor
portsing
Post by Professor »
They are KR1S barrels, origanaly tuned to stage 3 by stan stevens and I havent changed any thing drasticly on porting since buying the bike. The holes in the wossoner KDX piston are diffinatly slightly different postion compared to genuine kr1s. Maybe useful to have genuine kdx piston to compare?
Seems to be running in ok.
here is all the information on the KDX Woessner piston's :
viewtopic.php?t=7562
still : your exhaustports are too wide I recon :-k
Professor
port
Post by Professor »
I do have some spare kr1s barrels that are fairly standard I think so I'll have a look at them to compare
Anyone else been using the kdx pistons for long?
