circlip location clutch to gearbox
rebuilt today but found 1 circlip #-o ,same as the one over the clutch basket ,is there meant to be one under the clutch basket or is it gearbox side(i cant think why i would of removed it)
if its under the basket does anyone know the order say ,circlip shim then basket ,will have another look at manual now
,,,,think iv`e found it section 8,9 in pic 1 part A circlip ,sorted
that is correct fred.
[clutch side]
circlip
then washer
then outer clutch basket
then thrust washer
then inner clutch
then circlip
cheers martin ,another beer owed :oops: , i should of bagged the circlip then tywrapped in the right order with the clutch basket,thanks
