Not much of an update this week, I've mainly been working on the fibreglassing for the tank and airbox.
I have started to make a rear hugger though. From what you see in the picture, I will create a mould and then make the finished item out of carbon fibre, so will document those steps for you when I get to that point. It's essentially the same as fibre glassing, except you use a high gloss, clear resin instead of gel coat and you have to be careful not to disturb the weave when applying the fibre fabric.
- KFOR
TwoStroke Institute
TwoStroke Institute
So a 160-165 rear? That will increase grip levels by about a factor of a 1000. Probably even take some time to convince yourself just how insanely fast you can corner. Good suspension lets on the power much earlier. That should be a right weapon once finished. How you going with the ignition?
crochet & croquet
As promised here are the steps to creating a carbon fibre hugger.
I made the original out of a combination of fiberglass and David Isopon’s P38 & P40. It looks okay in the picture, but it’s as rough as old bollocks on the inside and weighs a shed load.
I had some nice green paint to hand, so went about using that up to give it a decent finish.
Next steps were to polish and cover it with the usual blue PVA release agent. Once the release agent is dry, you can give it a good covering of your gel coat. Allow this to cure for an hour or two, just so it’s tacky to the touch.
Once you’ve left it for a while, you can apply the fiberglass layers with your resin mix.
Allow it to dry thoroughly and pop the mould from the part. In this picture, you can see the blue release agent where it has come away from the mould. It’s like a water soluble skin.
Clean up the edges with the dremel and give the inside a polish with some T-Cut. Once polished, give it a good clean, otherwise the PVA release agent won’t apply evenly and you’ll have a nightmare with it.
Apply an even layer of release agent and allow to dry again.
Mix a small quantity of your clear resin. For carbon fibre, I use a high gloss clear resin, which is different to the fibre glassing resin. Apply the resin evenly to your mould with a brush and go over it with a heat gun. This gets out any air which was mixed in to the resin and gives you a glass like finish.
Allow this to dry for a couple of hours, so it’s gone off, but still tacky to the touch. Get your carbon fibre fabric and apply to the mould. I find it best to do this bit with your hands, being careful not to disturb the weave. Remember, this layer is the one you will have to look at if you cock it up, so do take care.
Once you have the first layer down, you can get some more resin and apply the other layers to complete the part allow to dry thoroughly.
Once dry you can remove the part from the mould, clean up the edges with your dremel and a file. Wash any residue release agent off, give it a polish and sit back and admire your work.
Thanks Daz for lending me your rivit gun and thanks for the rivits Fred.
- KFOR
