in the end i just slit em with a grinderete and flatted them on some emery cloth ,got a free dyno run at 2 so should show up if it works
here you go ,sorry of a mobile
dyno went ok .pulled well but then kept stutterering.it was 1 corroded pin in the ignition block.was still showing 55hp but how accurate god knows.put some rd142.5 in after i sorted the electricks,(the block was lubed up with chain lube 6 months back) just done a test up a long rising straight in 5. And the stutterings gone .and looks a bit rich .but thats cool.cant wait till sunday
