Wrong again 50 shades of Firecracker Red and Grey!500bernie wrote:Hi Pookie,pookie wrote:got this weird image of the door of the premier inn with a 'do not disturb' sign on the door handle with the staff lined up outside listening at the door with a wire brush on metal sound eminating from the room (may be the basis of my next book 'fifty shades of green')
No its "Fifty Grades if Wet n Dry"
- Binetta Steve
Roll on getting the paintwork done [-o<
- Binetta Steve
Bernie dont get despondant the rad sits behind the belly pan. No one , even you can see it. Just crack on and get it built !
- gary
Hi, bernie, u should think about dumping the standard rad, and run with the yzf rad, as u are runing with the 300 topend , that,s what am going to be using.
Using a non standard radiator does defeat the objective of a full restoration.gary wrote:Hi, bernie, u should think about dumping the standard rad, and run with the yzf rad, as u are runing with the 300 topend , that,s what am going to be using.
boggy
Hi Bernie,
You have come along way,why not get it refurbished by the experts?I know it won't be cheap,but at least it will be in keeping with the rest of the bike.After all you have managed to do most of the work yourself.I take my hat off to you for your dedication.Your bike will look immaculate once complete and something to be proud of after all your hard work.
Rich =D>
Rich =D>
Hi Rich,
The standard rad is a sad looking little thing, and I don't think a couple of out of sight improvemnts are going to spoil it.
Big shiny rad ordered
Something shiny arrived in the post
- tescr500
looking pucker there Bernie does the body work fi ok cheers =D> =D> =D>
Hi Wayne,
It is shorter than the standard unit, so I should be able to mount it higher to avoid contact with the fairing.
That will get looked at when I next get home. (and a polish)
Bernie where did you buy the radiator, in england or in china?
cheers Jarno
cheers Jarno
Hi Jarno,
In England (I think they are also available from China on ebay)
Hi Bernie,
ok but if i transport it from china the customs wil hold up there hand
is the radiator on fleebay?
cheers Jarno
cheers Jarno
maccas
It's the parts of the fairing that go back towards the radiator that foul on mine Bernie. The ends of the fairing catch right on the finned part of the rad. For mine to clear I would have to move the rad back by about 5-10mm towards the rear of the bike.
Yours may well be different though when you fit your fairing.
