C2 rebuild now underway (more pics)
Couple more pics.
Re: C2 rebuild now underway (more pics)
Lovely work mate....
- Top-shaggy
It's going to look better than new at this rate
That looks great =D> =D> =D>
The callipers look fantastic, what finish is that on them?
The probolts really finish it off.
Well done. Can't wait to see what the finished bike will look like.
Standard Suzuki finish, spent a while finding some nice nick ones but worth looking. Bolts are Ti ones off eBay. Calipers are so light compared to std although had to add a washer to centre them on the discs.
Next jobs are rear mudgaurd, fit the clocks and exhaust bracket then clean the powder off the mounts and get the motor in. Shims at the ready...
smoovly wrote:Standard Suzuki finish, spent a while finding some nice nick ones but worth looking. Bolts are Ti ones off eBay. Calipers are so light compared to std although had to add a washer to centre them on the discs.
I used some of these http://www.ebay.co.uk/itm/ZXR400-ZXR750 ... SwpDdU465T
Snap. But, still didn't quite line up as well as I would have liked. Should be ok with a washer, it's only the brakes so nothing too critical.
First lot of plating is back so at last I can start to put some bits on. Typical fab finish from Collins.
I've got some clear stuff being done next week so will post some pics of that too when it comes back plus some pics of the bike with some of it bolted on.
Pads & hoses ordered, Wiseco pistons coming soon then it's off with the barrels. Bank balance emptying at a shocking rate but I knew that was going to happen....
That looks good, never had any 'blacking' done before, it's either been zinc or yellow so far, whats the spring off? don't remember removing one of them, I'm just putting mine together too.
I think that the spring is a guard that goes between the rear brake master cylinder and the reservoir, it looks like the one on my kr-1.
Yep, it goes on the hose from the reservoir to the master cylinder.
Made tons of progress over the last few weeks.
Barrels have been to Aptec and Wiseco pistons from Jarno installed. Standard pipes have been painted and all zincing is done. Need some offset clamps for the JL cans, Tyga ones look like they will do the trick. Still looking for that elusive horn bracket and need to make a clutch cable loop for the clock bracket and get that re-coated. Was happy with it but now the clutch cable is on I see that it really needs it. KIPS system all sorted, went with the original valves as not too badly grooved, new seals, aftermarket rods and pattern cables. It's nice and smooth and hopefully won't leak.
Should be ready to fire it up in a few weeks once I can find my wife's spare hairdryer to get the airbox on.
More pics.
