Page 2 of 6
Re: Motor temp.
Posted: Fri Mar 14, 2014 6:18 pm
by headcoats
Is the new thermostat a good'n ?
Have you put the stats in boiling water to test them ?
Re: Motor temp.
Posted: Sat Mar 15, 2014 9:29 pm
by Mouser
The thermostat is a new original one.
What do you mean by stats..? sorry..don't really see..
Mouser
Re: Motor temp.
Posted: Sat Mar 15, 2014 10:37 pm
"Stats" Thermostats
Re: Motor temp.
Posted: Tue Mar 18, 2014 10:07 pm
by slashing
Have you had the head off if so did you use a genuine head gaskit as pattern once dont seal to well unless you use a sealer?
Re: Motor temp.
Posted: Wed Mar 19, 2014 6:18 pm
by Mouser
Hi,
Don't know if the head gasket was changed. not by me yet.
Could this be the reason? wouldn't then the bike smoke clearly "white" and the water level be going down little by little?
Mouser
Re: Motor temp.
Posted: Wed Mar 19, 2014 6:45 pm
by jarno
maybee the changed the headgasket and used to many sealend and the cooling poorts are seald shut , than the water cannot run the normal route thrue the head and it wil be getting very hot.
Re: Motor temp.
Posted: Wed Mar 19, 2014 9:14 pm
That's actually a very plausible explanation Jarno. This over heating issue has had me a bit puzzled. I certainly don't think you'll get anywhere with it, unless you start taking things apart and inspecting stuff. I would still pull the head off and check it's straight.
Re: Motor temp.
Posted: Thu Mar 20, 2014 10:16 pm
by Mouser
Hi,
Will check that next week, hmm too much sealing compound could be an explanation..
I'll report..
Mouser
Re: Motor temp.
Posted: Thu Mar 27, 2014 9:24 am
by dirk
jarno wrote:maybee the changed the headgasket and used to many sealend and the cooling poorts are seald shut , than the water cannot run the normal route thrue the head and it wil be getting very hot.
Hello Mouser
what Jarno wanted to say.
so it should not be ..
cheers
Re: Motor temp.
Posted: Thu Mar 27, 2014 11:20 pm
by Mouser
JESUS!
Which jerk...what the f...
how stupid can one be to put 300 kg of gasket seal on the head!
hope it wasn't you..
Regards
Mouser
Re: Motor temp.
Posted: Mon Mar 31, 2014 10:29 am
by Mouser
So cleaned the radiator..changed nearly nothing.
Going to change the head gasket then..anyone know where to get only the head gasket, not the full set?
Which make do you recommend?
Mouser
Re: Motor temp.
Posted: Mon Mar 31, 2014 10:41 am
Only use OEM gaskets and do not use any sealant.
Re: Motor temp.
Posted: Mon Mar 31, 2014 2:22 pm
by Mouser
Ok, thanks!
Re: Motor temp.
Posted: Sun Apr 06, 2014 8:18 pm
by Mouser
Hi,
So I took off the head, there is very little sealant used but nothing in the holes, so nothing really seems to obstruct the water flow...
The sparks plugs are BR10EG.
Here are some pics of the head and piston.
The right head is quite scratched, the left one very clean.
What are thoses scratches?? Did those come the the piston??
What can be this overheating problem then?
By pusching the kickstart the pump drive does turn with, so it seems to work properly.
Mouser
Re: Motor temp.
Posted: Sun Apr 06, 2014 8:19 pm
by Mouser
rest of the pics.
