How does those settings feel on the road?
I really need to get mine across to Mick Abbey and get it set up on the dyno, I am sure that the jetting needs a bit of attention to.
Agreed.maccas wrote:Doug,
You need to flick the pv's from open to closed much quicker than that.
Try 7900 0% and 8000 100% that should be about right.
Dan
No prob Bernie, hopefully the open/close points will help get in near straight away. As Dan suggested I'd go initally with a straight open/shut at whetever revs you pick then see how it rides and mess about from there. Out of interest I once tried 100% open, then 100% shut, just to see how the motor rides in both states. Badly, was the answer500bernie wrote:Thanks Doug
