smoke out of one can
- mr_bungholeo
nickclem
Hi, it's been a while since I’ve been on here and to be honest I’ve been flagging a bit in getting the bike sorted. While speaking to my friend he mentioned maybe the fuel tap being blocked, if that was the case would it of caused these problems? and if so does anyone know where i can get one cheap? cheers
- rc46
mgtkr1
stator? if it has nipped up you may get away with cleaning the bores with a light emery rub(if its marked the plating) or if evidence of molten alloy appears then acid can be handy. a new pioston/rings etc should see you right but id be inclined to give it a full rebuild as the cranks seals are prone to fail after long periods of standstill. its not forced to be this tho, could be something minor even a loose/faulty plug cap! i would check the ignition over.
thefallenangel
thefallenangel
Lol just found out the problem was the crank seal going and a piston getting partially chewed in the process. Luckily those RGV converts are in and ready to go.
2 Strokes are like women.
When they work they are the funnest things in the world but when they don't work they are a drain on your wallet.
nickclem
well finally got round to having a look at the bike, checked the rings and they seemed to be fine, started the bike up and as before it was running on one cylinder, I then removed the spark plug from failing barrel and checked for a spark which it did have, but a very irregular one so I’m going to get the stator checked over, I’ll keep you posted
geezagillard
I had a similar problem at the track last year. Bike started cutting in and out and the plug colour on one side was much darker and greener than the other. Looking behind the bike I had a load of smoke coming out one exhaust whilst the other ran fine. Bike started and idled fine and fuel and oil supply seemed fine. Had a guy approach me in the pits and suggest I had a crank seal gone and of course he was right. The extra smoke was from burning the gearbox oil and colouring the plug accordingly. Have only just recently stripped it and both seals looked like year old donuts. The outside seals looked good but would suggest replacing all. Sam from BDK is supplying and was fast and easy to deal with. Unfortunately it means a complete strip as you have to split the cases to get at the crank. Crankseals not are apparently quite common on the KR1.
- nate
Hi Gizzard...
Strangely I have a similar fault after completing a rebuild... Haven't had it out on the road yet... but it starts first kick, idles fine... but smokes on the right hand exhaust, not the left... Is this similar to yours?
What colour should i be looking for on the spark plug and which Cylinder???
Nate
P.S. about to start checking everything else in the mean time
Nate
geezagillard
Also beware that if one of the outer crankseals leaks the opposite happens and the faulty cylinder will smoke less (if at all) as the engine is sucking in air and burning lean (can also be caused by any air leak downstream from the carbs as well). Give it a hand full in this condition and it'll eat a piston.
PS it'll take ages to clean all the molten alloy out from the crankcases, cylinder and exhaust and you run a high chance of distroying the crank as well.
- kwackman12
This is exactly what happend to mine! was running fine then started to loose power pulled into the pits smoke was pouring out of the right hand exhaust, sent crank to bdk the seals were totaly shot! Also when I started it up today (first time) since rebuild smoke was pouring out of both exhausts, probably due to me using a lot of two stroke oil during rebuild & the oil residue from the blown seals! but it has cleared up now. although I expect it to smoke a bit more once I can get the exhausts really hot.
So dont worry Nate, think it will be ok, just get out there & ride it
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
ZXR 400 Race Bike
Aprilia RS250
Well Mine suffered a simular fate. Engine would be fine for ages then the LHS would not smoke much while the RHS smoked loads. Not using an gearbox oil so I guessed it was the outer crank seals, Wrong.
New seals fitted, engine rebuilt, BANG
. Crank rebuilt, new pistons etc. Took it out for its first run, every thing fine, then BANG
. Stripped down to find that the engine had nuked it's self on the LHS and left a hole in the piston as that side was running lean. Checked all the common parts for a fault and can't find an air leak, crank seals ok etc. After much head scratching that left me looking like a monk
, I eventuatly found the cause.
The LHS bottom crack case at the rear wasn't flat and dropped about 0.32mm in the middle. The engine was running fine until the sealent blew out of this gap, and allowed the cylinder to suck air and nuke it'self. Thing was it must have been like this for 18 years
but was fine when using the original Kawasaki sealent, but the newer stuff I use now obviously can't fill that sort of gap for long.
Used Devcon liquid titanium to raise the crank case face and machined it flat once dry, and all is now well. Just goes to show that if its possiable to go wrong, it will and never in the obvious way.
