Turn engine over and undo the bolt holding the water pipe.
Turn engine backover.
Clutch side undo the clutch/engine cover. On teh water pump cover only undo the lower rear bolt - that one holds the engine cover on. The other two just hold the water pump cover to the engine cover.
With all the bolts undone carefully remove the cover - it has to come off the water pipe, and the kickstart shaft.
With the cover off remove the kickstart shaft - I pull the pin that the spring is attached to out. Be careful there is a washer behind the kickstart which tends to stick to the cases.
Spin the motor round - remove the flywheel need a puller for that. three allen bolts remove generator. Three cross heads hold the timing cover remove those and the timing cover.
Turn the engine upsidedown.
Balance weight cover remove the 8mm head bolts. Remove the tapered cross head at the front of the cover (KR-1S only). Undo the 4 x 12mm head bolts in a cross pattern a bit at a time just to loosen then completely.
Lift off the balance weight cover - don't loose the two locating pins (haven't mentioned those before there are two on the gear selector cover - in fact two on all covers).
Lift out the balance weight - dont loose the rubber bit at the end. Put somewhere safe. (when putting it back it has two punch marks on teh gear these align with teh same two marks on teh crank gear). Don't loose the two half circle steel locating clips.
Next undo all teh 8mm head bolts holding the crankcase halves together.
Next the 8 x 12mm head bolts - half a turn at a time work around the numbers in reverse order. Repeat twice then undo all teh way.
Split the cases
Thats it
