Page 2 of 2
Posted: Tue Jan 02, 2007 11:12 am
by frog32
nooooooooooooooooooooo
you can,t put a electric engine in your bike
(it would be like havin sex and only using half you d!"k
http://www.prox.co.uk/
there very good price wise
cheap pistons//rings ...no as well go japanese nothing else a few quid save now will almost deffo result in another rebuild later on mitaka are the best piston kits imho
take up elfs offer
and look into the postage from parcels2go
heres the link
http://www.parcel2go.com/?lpsrc=overture
well you,ve nearly drove me drink (its a good job the offys shut )
Posted: Tue Jan 02, 2007 1:19 pm
by the-elf
Yep Make me an offer for the two cylinders and pistons and they are yours. I've got no use for them and they are pretty good. I also have some nearly new rings, so all you'll need are some little end bearings. Check that your crank is good though before you put it all back together. It'll be a PITA to rebuild her only for the same thing to happen again if the crank needs rebuilding.
Also look at it as an investment cause these bikes are getting rare and are beginning to go up in value.
Posted: Tue Jan 02, 2007 1:54 pm
by SHimmer45
tht is true, decent KR's are beginning to fetch good money.
Posted: Thu Jan 04, 2007 12:02 pm
by slydesigns
not in NZ they arent, there are too many toys in this country being dumped here from japan for anything to go up in value. Take my 95 h***a Accord Manual H22a VTEC Coupe on Nitrous, its JUST another car here. And my KR1 cost me $1000NZ (about 300pounds to you guys) last month!
I REALLY want your barrels and pistons please, and gaskets and what ever else I can get.
PM me a ball park figure please. Same to anyone else with any parts at all.
So far I have 2 gearboxes, 2 clutches, 3 carbs, 2 brand new carb boots and heaps of little parts.
Posted: Thu Jan 04, 2007 1:12 pm
by the-elf
Checked postage costs and they were about £70 for a 10Kg package. If your still interested at that cost then make me an offer and they are yours.
Posted: Mon Jan 08, 2007 5:15 am
by moltenmaniac
thanks for checking but itll be too costly for me right now, gimme a year (will have finished uni and have job) and ill be keen though!
Posted: Wed May 14, 2008 4:07 am
by moltenmaniac
Update on the project time
just started working on it, got motor (18hp peak) which should be able to get it to around 130kmhr, if i stick to the manufactures specs this will take a while, however if i just overload the motor (and add a good cooling system) it will have proper motorcycle performance.
However the problem i have run into is the fact that almost nobody can certify electric vehicles, with petrol hitting 2bucks a litre this seems rather f**ked up. So ill register it as a moped for a while (50kmhr and 2kW limits
) and just switch off the limiters when i need to do some proper testing. This will also allow me to change as much shit around as i want as mopeds dont need to be certified or checked at all.
Posted: Wed May 14, 2008 11:38 am
by col
slydesigns wrote:not in NZ they arent, there are too many toys in this country being dumped here from japan for anything to go up in value. Take my 95 h***a Accord Manual H22a VTEC Coupe on Nitrous, its JUST another car here. And my KR1 cost me $1000NZ (about 300pounds to you guys) last month!
thats exactly what i wanted to hear with me only 6 weeks away from moving over there
Posted: Mon Apr 26, 2010 10:27 am
by moltenmaniac
another update time, still not finished though, hoping it'll be running in a matter of weeks rather than months now. If anyone is interested in progress? I can upload a more detailed description.
Posted: Mon Apr 26, 2010 10:30 am
by Charles
moltenmaniac wrote: If anyone is interested in progress?
yes, please!
Posted: Mon Apr 26, 2010 11:03 am
by moltenmaniac
OK, progress report copied from other site and edited a bit.
Got a kr-1s a few years ago to do up and put on the road, in fixing we got rings that had a different configuration at the split, long story short, the barrels now have a score through the nikasil powervalves were flip anyways so i decided to give up, by the time i get money to fix it properly ill be able to afford an aprillia rs250 (possibly considered prfanity on this site
) anyways.
Firstly i ripped out engine, cleaned and CADed up the rolling frame.
I obtained a motor from us (when nzd was at is max ) its an Etek-R which gives max power of 18hp, and continuous of around 10, which is bugger all but with a fully faired bike it should do a hundred easily.
mounted the motor onto the swingarm itself as it doesnt weight much and this eliminated the need for chain slack, thus slightly increasing efficiency.
ull notice some cnc maching on the mount, courtesy of my part time job at massey uni.
also got chain and sprockets custom form nz sprockets, 14tooth over a monster 68 tooth, i machined 4/5 of the weight out of the 68 tooth and mounted in place of the original
got some cheap agm deep cycle lead acid batteries (well cheap compared to the fancy batteries anyway!), welded up a battery box for them and stuck in.
got the e-stop made and stuck in now too
So work left is basically all circuitry, PWM controller, pack voltage to 13.4V converter, mains charger, and main control and monitoring circuit. I also have a few aesthetic bits to do, suck as replacing the KR-1 with KR-E on the lower fairing, and swapping out the tach dial with this
Posted: Mon Apr 26, 2010 11:52 am
by alimorg
Excellent!
KR-1E Electric KR-1 EV
Posted: Thu Aug 13, 2015 9:54 pm
by KR-1R
