I've not finished messing with the fairing yet, but the RSW is a lot different to what you're used to with the KR.
It has a modern pointier nose cone, which elongates the shape.
Because I have limited space in my garage, I also can't photograph the build any further back, because my SV is in the way. This means I'm taking the picture from a higher position and closer up, than the example above, so makes it look slightly different.
If the fairing was further back, it would also be hitting the bottom yokes when turning.
As you can see in the example RSW, the belly pan is very close to the front wheel. Clearance is a little tighter on mine at the moment, but will be extended by a few mm once fitting is completed and I have all the brackets.
