Page 2 of 2
Posted: Sat Dec 31, 2011 1:36 pm
- sure the carb's get enough fuel ? when you detach the fuellines, does the fuel flows nicely ?
- never mind what the manual says about the airscrew : it's way too lean. start with the screws turned out only half a turn
Posted: Sat Dec 31, 2011 1:44 pm
by tescr500
no i can understand but everything is how it should oil pump bled every thing cleaned just about to have a re try with every thing normal back on there bar a couple of tweeks cheers
Posted: Sat Dec 31, 2011 2:23 pm
by tescr500
Hi All storie so far, put me k's back on plastic bits back in, raised needle to highest position, air screw out half a turn and runs sweet as, nice and crisp spot on, will not know plug chop untill she's road worthy and at least has some breaks cheers alll wayne.
Posted: Sat Dec 31, 2011 4:31 pm
Well done Wayne =D>
Posted: Sat Dec 31, 2011 4:42 pm
by tescr500
cheers Bernie had to get it sorted before i carried on with build, nothing worse than trying to fix a problem at the end when your finished when all is you want to do is ride it like you stole it. \:D/ \:D/ \:D/
Posted: Sat Feb 25, 2012 9:40 am
by slashing
Best bet stick it in a dino thats what i had to do with my 300cc kit.
Posted: Sat Feb 25, 2012 3:09 pm
by tescr500
Hi slashing, i'll definitely be doing that when she's done, interested to know what she's pushing cheers Wayne.
running fault
Posted: Sun Feb 26, 2012 11:51 am
by slashing
The dyno is the best way to go its so easy to hole a piston on a tuned barrel. I have a running problem with my bike at the moment i took it to a near by bike shop which has a dyno it was run and he found the fueling was good so it points to an electrical fault on the left hand cylinder i cant find whats wrong with it tried two coils two cdi an one pick up coil may be check the stator next.
