you need to get a machinist take the taper out so it fits the crank and then position your pickups, so not a lot of work.
I am going to try some different pistons, from the flat top single ring Mito pistons to the TZ 3TC's.
I have an ignitech already, so will try a zeel on this one.
Post by jarno »
show us some pictures whem you are building it :lol: :lol:
opened an other engine yesterday and found this
is it some kind of liquide metal the put in there or something els.
looks a right mess and yes I'll photograph the motor as I build it. Just started stripping it down today, as I'm taking the crank in next Monday and I want to take the cases for vapour blasting at some point soon.
mj43
Post by mj43 »
jarno wrote:show us some pictures whem you are building it :lol: :lol:
That may well be the most advanced set of KR cases I have seen to date.
If it is what I think it might be what you call Liquid Metal should be a thermal barrier ;)
Post by jarno »
didn't know that it seems like a lot of work to do that.
also have racing barrels with the engine but i don't know if there the matching barrels for the engine.
mj43
Post by mj43 »
There was info on thermal barriers on Pit-Lane web site. A place in the Netherlands sells the stuff. Aim appears to be to prevent heat transfer to the charge in the crankcase.
Post by jarno »
did't know that
did it help?
I thought it would be best used in the combustion chambers on the piston crown and head.
Shall we try it on my engine Mark?
And isotropic (super finishing) the gears/gearbox
TwoStroke Institute
Post by TwoStroke Institute »
Martijn Stenhouwer from Emot Racing offers that service but much speculation that it is common Russian house paint :wink: Worked well on a 50cc engine though.
The $30 paint on ceramic coating will cause more deto than it stops. Got to look in quite a few works Aprilia RSA engines at the GP and didn't see any shiny gears :wink:
Just message me before you start the 110 rod engine Ben
crochet & croquet
cheers Lozza
I've just had confirmation today that my crank is ready to collect, so I can start work on the motor very soon, as this has been holding me up a little lately.
I have been working on securing the fuel tank and also done some further work to the swing arm.
mgtkr1
Post by mgtkr1 »
who did the swingarm?
It's a combination of my mate Rob, an engineer called Mike Tunnicliff, Nigel Kimber and me
