New Build Project - KR-1 with 421 Athena Banshee motor.
RickNC30
Re: New Build Project - KR-1 with 421 Athena Banshee motor.
Post by RickNC30 »
Back to work...
New, shorter high tensile head studs fitted, head domes installed, all sealing O-rings held in place with silicone grease -
Head installed with refurbished water joint and new hose & clips -
VForce Four type reed cages with British made Showe reeds, 34mm carb adaptors -
First complete bolt together with PWK34 carbs and Ramair filters just to check that everything fits -
There`s still work to do - check squish clearances, shorten the inlet balance tube because the ends stick too far into the bigger carb rubbers, drill and tap those little bosses next to the chokes on the carb bodies and fit some kind of nozzles for the oil injection system - but overall it`s looking like an engine package that means business so I`ll probably be dragging the chassis back out of the corner next weekend...
RickNC30
Post by RickNC30 »
As per the end of my last post, squish clearances have been checked by inserting the end of a suitably shaped length of 3mm soft solder into each side of the combustion chambers and turning the engine over - all good at 1.2-1.3mm. The brass fittings and sealing washers are ready for the carb mods -
The manifold balance pipe has been trimmed so it no longer intrudes into the inlet rubbers -
Those bosses on the carbs already have a cast in 3.9mm blind hole so I drilled that to 4.2 mm and tapped an M5 x 0.8 thread -
- then installed the brass hose fitting and using that as a drill guide bored a 2.5mm oil injection port through into the carb throat -
The `pull button` choke plungers will be replaced by cable operated ones when I get to the final build.
RickNC30
Post by RickNC30 »
I found myself with an hour to spare last night so I thought I would bite the bullet and fit the completed engine to the rolling chassis.
Happily no real problems - the way the frame has been modified means that all I had to do was unbolt the detachable cradle, bolt that to the engine then put the whole assembly on to a jack platform and stand the chassis over it, raise it to the correct level and bolt everything back together again...
nice 8)
RickNC30
Post by RickNC30 »
Footrests and controls next - when I built my last KR-1 I designed adaptor plates to use an FXCNC NC30 rearset kit on that bike so I`ve gone with the same set up again.
The brake side uses an FXCNC master cylinder with a built in piggyback reservoir which saves space, hydraulic brake light switch keeps that simple -
- luckily there is plenty of kickstart clearance so I didn`t have to worry about making up a folding footpeg arrangement -
Gear linkage uses a new RC30 front arm that was in my `it`ll come in handy one day` box and an industrial grade sealed rod end bearing at the rear. Prop stand has been lengthened a couple of inches to accommodate the bike`s taller than stock stance - everything has just the right amount of clearance and tucks away neatly -
The ZX-6R clutch lever that I was planning to use just wasn`t compatible and gave a horrible action with no feel so I have replaced it with the stock 350 YPVS assembly -
Looks all wrong mismatched with the silver lever on the Nissin master cylinder so I have ordered the black front brake lever from a 2013 GSX-R1000 to replace that.
I had five sets of those footrest adaptor plates made so I have a couple of sets spare if anyone needs them.
My fabricator is today making the jig and prototype for an aluminium version of the front fairing bracket - if there is any interest I will also have a batch of those made...
Post by pookie »
Project is looking great, now that the nights are drawing in here in the UK i'll be fettling more, I'm not that mechanically minded so I just fettle, not tinker, I like the ''It'll come in handy one day'' box, I've got a ''It'll come in handy one day'' loft! think there's half a Kr-1 up there :shock: keep up the good work.
RickNC30
Post by RickNC30 »
Next job will be to fit these little beauties -
- another ebay bargain that I picked up a few years ago, shortly after I bought the modified frame - a brand new, still boxed pair of stainless steel JL expansion chambers made to fit a 350 YPVS with a Banshee motor, presumably from someone`s abandoned project as I picked them up for around £500. I`ve fitted Tyga mufflers, the same pipe/silencer combination that I used on my KR-1 project.
It looks as though they will fit pretty well despite being designed for the stock Yamaha chassis, main job will be to remove those hanging brackets from the tail pipes as there`s nothing on the KR chassis to connect them to. The only snag I can see at the moment is that the stand catches on the left chamber - it`s the spring hanger which causes the problem so I need to relocate the return spring on to the outside of the stand, cut that hanger off the inside and that should fix it...
starting to look great 8)
RickNC30
Post by RickNC30 »
Fuel Tanks - this would be funny if it weren`t a total f*ck up which is going to seriously delay my build.
A local fabricator whom I deal with fairly regularly told me he had some experience with building alloy tanks for motorcycles so I gave him my one remaining KR-1 tank to copy - two years later he has finally delivered this...
Even leaving aside the quality issues with the construction and finish, it seems that he has measured and copied the top shell of the tank, done the same with the base and then welded the two together facing in opposite directions! FFS, he had the standard tank right there as a reference...
On the subject of confounded expectations - here are two alloy fuel tanks, one made by an English artisan with 40 years of fabrication experience, the other by a guy in a back street workshop in New Delhi - can you guess which is which...?
Furthermore, can you guess which one I`m now going to ask to make the tank for my bike...?
RickNC30
Post by RickNC30 »
Not much moving with the bike at the moment, I`m on to some of the fiddly stuff like sorting out the exhaust routing, making up radiator mounts and hoses and getting custom control cables made - in the meantime my fabricator has come through with the alloy front fairing bracket -
It`s fairly basic, deliberately constructed from alloy bar rather than tubing in order to make it crash proof (solid bar does`t kink or crimp, so if the bracket gets bent you can simply pull it back into shape) but it`s still significantly lighter than the steel tube original - we have included the headlamp and speedo mounts though I don`t have any of the necessary stock components to actually test the fit.
He has made a jig so we can produce a batch if anyone else wants one...
RickNC30
Post by RickNC30 »
I`m embarrassed to admit that I`ve just had one of those `Doh!` moments...
I set about fitting the exhausts - the right chamber went on OK other than not meeting the stub on the barrel at quite the right angle, it sat nicely but seemed to hang out a bit far and looked like it might cause problems with cornering clearance -
- then I offered up the left one and it was nowhere near fitting so off they came again.
I was taking a good look at everything and thinking `why are those chambers completely different shapes?` when the penny dropped...
Once I`d realised that my ebay purchase was a crossover system it all looked much better - the fat part of the chambers is now tucked well in under the sump and the only work I need to do is re-routing the stinger pipe on the left chamber to clear the single sided swingarm.
Been building bikes for 50 years and still not immune from missing what`s right under my nose...!
Rick, none of your photo's are visible, even the old ones
RickNC30
Post by RickNC30 »
Anyone else having problems seeing the pictures?
They are Photobucket links - everything is OK with my account and the pictures are visible on all my devices...
Post by SP_BOTT »
All the pics are fine with me, great to see a bit of life in the forum as well, enjoying the updates so far. :D
Hi Rick,
The project is looking brilliant, can't wait to hear it on the dyno 8)
