Page 3 of 13
Posted: Wed Aug 26, 2009 7:53 am
by kr1stian
Hi guys!
I'm fresh member at your forum.
I have one of five KR-1 (B1) ever imported to Finland and as far as I know there is only two examples running here both at Helsinki capital city area. No S-versions exist here. Please correct this if I'm wrong. I also have Z1-R for daily runs.
I have been lately working with exhaust chambers and I have now third good version coming for next summer. My aim is beat the stock S-version, not only in weight :). I use MOTA for calculations and Rhino for modeling.
My new project is maybe more ambitious one as I am re-designing the cylinders. Now, after modeling phase, I'm looking for right manufacturing process particularly for my project. Later I may expose more about this project if someone is interested. So if you didn't heard this efford later I may screwed up...:-$
I need new set (4) of exhaust valves for my becoming cylinders. If there is still one set to sell I would be very happy to buy one.
How can I send private message for certain member (in case of bank account info etc.)?
Cheers, kr1stian
Posted: Wed Aug 26, 2009 8:04 am
by Charles
Hi kr1stian,
welcome to the forum!
kr1stian wrote: I need new set (4) of exhaust valves for my becoming cylinders. If there is still one set to sell I would be very happy to buy one.
yes, still got 4 sets available, so you can have one set, no problem.
To send a pm, just click on the pm button under a member's name.
Posted: Wed Aug 26, 2009 2:07 pm
by Charles
only 1 set to go and the whole batch of 100 valves will be sold. \:D/
Hope to get a date tomorrow when they very likely will be ready for dispatch.
Posted: Thu Aug 27, 2009 6:53 pm
by Charles
The Elf's valves are being measured now, drawings of them are currently being made. Will check on them tomorrow.
Aluminium has been ordered.
Valves will be ready no later than September 15, probably some days earlier.
Posted: Thu Aug 27, 2009 8:29 pm
by Steely
You're doing a great job charles, keep up the good work.
Posted: Thu Aug 27, 2009 9:03 pm
by Leewc
Just to clarify, these won't fit KR1 B2 cylinders will they?
Am i right in thinking they use different size PV's.
Posted: Thu Aug 27, 2009 9:14 pm
by Charles
Leewc wrote:Just to clarify, these won't fit KR1 B2 cylinders will they?
They will fit, you just have to use a dremel to widen the KIPS port a bit. I use KR1-barrels too.
Leewc wrote:Am i right in thinking they use different size PV's.
yes, the holes in the valves are different (the KR1S got larger ones). The (external) dimensions of the valves themselves are identical.
cheers,
Posted: Thu Aug 27, 2009 9:23 pm
by Charles
Steely wrote:You're doing a great job charles, keep up the good work.
No, it's not a great job. I've only just found out what this mate of mine is able to manufacture. He can nearly make everything we may come up with: KIPS valves, KIPS levers, clutch stars, etc.
Posted: Fri Aug 28, 2009 1:46 am
by rgvlee
I'd dare say if you got sets of the linkages made up you'd have a few takers, me included.
Posted: Fri Aug 28, 2009 5:47 am
by Charles
rgvlee wrote:I'd dare say if you got sets of the linkages made up you'd have a few takers, me included.
That will be the next project then :D
Posted: Fri Aug 28, 2009 10:33 am
by fatboy
Hi charles
is the last set still available if so put me down for them
cheers
Posted: Fri Aug 28, 2009 10:36 am
by Charles
fatboy wrote:Hi charles
cheers
yes, it's still available, will add you to the list.
So far production hasn't started so I can still order extra sets, the more the better.
thanks,
Posted: Fri Aug 28, 2009 4:09 pm
by Charles
Charles wrote:The Elf's valves are being measured now, drawings of them are currently being made. Will check on them tomorrow.
Newsflash :D : drawings haven't been finished today :(
Will get a copy of them on Monday.
Posted: Fri Aug 28, 2009 8:55 pm
by Del
Hi Charles,
I've arrived a bit late to this , but put me down for a set too please if it's still possible.
Thanks,
Del
Posted: Fri Aug 28, 2009 9:23 pm
by Charles
Del wrote:Hi Charles,
Thanks,
Del
no problem, one set for you.
cheers,
