Ready for balancing!
Speaking of balancing, I understand most of what you guys are saying. Smithy, I understand what you mean by more weight off the side opposite the pin but keep in mind the KX piston is half the weight of the RZ piston and the rod (while the same ctr to ctr length) has a smaller pin size also. There is alot of weight being reduced on the pin side, just at the piston. Not sure if that is the same though. But again, not my problem. The guy doing the balancing has that task. I just write the check.
[/img]
