Who is racing in 2010
Tell us where you are racing we might pop along and offer support!
kwackman12
Post by kwackman12 »
Rocket wrote:Thanks for the info, nice one kwackman12, photo makes my bike look shabby, need to spend more time on bike and less on here, are you running a 18" rear, if so, what tyres are you using and where did you get a tyre warmer to fit it from.
Still running a 18" rear & using Dunlop Alphas, this guy will make you a set of tyre warmers if you need them ian@tyre-warmers.co.uk think they were £98.00 helpful guy & he own's a couple of KR's I think
Charles wrote:great results, Gary! =D>
Thanks Charles
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
Yatsushiro
Post by Yatsushiro »
Gary
Good to meet up with you and Emma on Saturday. Well done on your results.
I managed to get an 8th and 9th on the TDR in the YPM races, lapping in the low 2:04's
Oulton is a fine track, particularly when blessed with the weather we had.
See you at Pembrey...
kwackman12
Yes nice to put a face to a name Paul, have you recovered from your barbecue :mrgreen: my best lap was a 2;12 might be asking you for a few tips at Pembury :) are you getting there for the practice session on friday?
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
KwakOn
Re: Oulton Park
Post by KwakOn »
kwackman12 wrote: second fastest rookie
=D> =D> =D>
.. Image ..
mj43
Post by mj43 »
Rocket wrote:I am hoping to run at Cadwell 2nd/3rd May with Derby Phoenix on a KR1S, not a very good one but runs ok at moment, 1st time racing, done a few trackdays, any help or advise would be good.
I see you have also gone in the 675 Allcomers as well as the F400 - well done :) It is worth doing and is excellent value for money in terms of track time.
Rocket
Post by Rocket »
Yep, think I need as much track time as posible, just dumped the race at copice bike at cadwell this evening doing some practice laps , loads of damage, will have to work a few late nights and hope I have all parts needed to get it going again.
mj43
Post by mj43 »
How? what happened..
Rocket
Post by Rocket »
Don't really know what caused it, front went exiting copice and I slid on to grass, bike not as bad as first thought and I have most parts to put it back together, need the following though:
footpegs
gear lever
clutch lever mount
steering damper
fairing
screen
will source these over the next few days while getting frame welded,
if any one know where to get any of these bits it would be helpful.
mj43
Post by mj43 »
Probably have but depends on answer to question
By footpegs do you mean standard?
What sort of steering damper?
I have
Gear lever
Fairing raw white (In fact have full body set in white)
Screen - no
Assume it was dry
Mmm... exiting...
Tyres what size front and what size rim?
Tyre pressures?
Rear suspension not too soft allowing bike to squat unloading the front?
How many laps into the session and was anything different to previous laps?
Rocket
Post by Rocket »
Race pegs with nylon end.
NHK steering damper (cheep but worked ok).
will pm about gear lever and fairing.
dry track,
evening, so was cooling down,
120/70/17 Dunlop alpha on 3.50 rim, 150/18 alpha rear,
was 30psi cold when checked before going out,
rear suspension probable too soft for me (90kg undressed),
rear static 0mm, rear dynamic 30mm (without riding gear on), think I need to get suspension set up,
4th lap into session, only thing different from previous laps, no slow 4stroke in front of me, I was posible carring much more corner speed than previous laps,
Also I have been trying to alter my riding style to suit the 250 from riding big 4strokes and supermotos on the road for the last 20 years.
mj43
Post by mj43 »
You should be able to take Coppice flat out in 6th (takes very big balls - which I don't quite have always roll off a tadge).
Worth checking the spring rate probably need something about 90 to 95kg for your weight. Stock springs are a little soft and people tend to try and compensate by winding in a load of pre-load.
kwackman12
Rocket wrote:120/70/17 Dunlop alpha on 3.50 rim, 150/18 alpha rear,
I run 30psi rear (Hot) & 26 front (hot) this has made a lot of difference to the grip
I used to check the pressures cold but after a qualifing session at Oulton park there was 44 psi in the rear when I left the track!!
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
Rocket
Post by Rocket »
Bike back together at last, THANKS to all who have helped, just need to set it up as best I can and give it a run up the lane to make sure all is working ok.
Am a little worried I have the rear wheel spacers in the wrong sides,
14mm on left (chain side)
11mm on right (disc side)
all looks to be inline though.
sauvage84
Post by sauvage84 »
We organise a very nice "demo" near Mt Ventoux in Provence and we can receive strangers racers
you can send me with MP or read our website : http://www.asso-mc2a.com/veaux-malaucene-2010
mj43
Post by mj43 »
Rocket didn't do badly at his first meeting.
http://www.photobikes.com/Derby-Phoenix ... 3399_wYExQ
